Complex triangle equality & Sin(ntheta)/Sin(theta)
  • Thread starter Thread starter Verdict
    Complex Triangle
The discussion revolves around two problems in complex analysis. The first problem involves exploring the conditions under which a triangle formed by complex numbers satisfies certain equality conditions. The second problem focuses on the expression sin(nθ)/sin(θ) and its relationship to complex exponentials.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of complex numbers and their properties to analyze the triangle equality. There is an exploration of rewriting expressions in exponential form and the implications of identities related to sums of complex exponentials. Questions arise about the validity of certain manipulations and the interpretation of results.
Participants are actively engaging with the problems, sharing hints and insights. Some have provided guidance on rewriting expressions and exploring relationships between the components of the triangle. There is a recognition of the need to clarify assumptions and definitions, particularly regarding the nature of the triangle and the properties of the sine function in the context of complex analysis.
Participants note that the original poster is early in their course on complex analysis, which may limit their familiarity with certain concepts. There is also mention of homework constraints that may affect the approach to the problems.
  • #31
Verdict said:
Looking at RHS, the first term just disappears. The second term though, again, can I say much about it without knowing n?
try it first (ie θ = π/2) for n odd, then the RHS is … ?
then try it for n even, but first divide both sides by cosθ :wink:
  • #32
Alright, so I tried for n = 5, which gives 1/16 on RHS and 1 on LHS, so indeed the factor works out as 2^(n-1). Not a general proof of course.. Still have to figure that one out. Is there an identity for this?
But for the even, how can you divide by cos theta if you set it is equal to 0? (pi/2 for theta)
  • #33
hmm … even for odd n, it's not as easy as i thought it would be :redface:
you can divide both sides by cosθ first, to give you a general equation, and then put cosθ = 0 :wink:
(and I'm off to bed now :zzz:)
  • #34
Yeah, I can't really see an easy method too :(
And yes, dividing by cosine first is the only thing that makes sense I suppose, but that makes it a bit more complicated than it was! It was all so pretty..
Anyway, thanks a lot for the help, I think I will give it a rest for now too and look at it again tomorrow.
  • #35
The professor suggested looking at Chebyshev polynomials, does that make any sense to you?
