Complexification for finding a particular solution
  • Context: Graduate
  • Thread starter Thread starter marmot
    Particular solution
3 replies · 3K views
marmot
So I have this:
y'' + 4 y = 4 sec(2 t).
which translates to
p(D)y=4sec(2t)
where
p(D)=D^2+4
where D is a differential operatior
I know i have two choices for this, which is either looking for the particular solution through variable parameters which involved the winkonsian and some integrals, or just complexifying
if i complexify
i get p(D)y=4exp(-2ti) because cos(2t) is the real part of this exponential
because the equation is linear I can do this
y_p=4exp(-2ti)/(p(-2i))
where y_p is the particular solution.
after a lot of algebra, i find that the real part is
y_p=(-16cos(-2t)-32sin(-2t))/80
which doesn't look like all like the correct answer, which has a logarithm which means there is probably some integration involved. why does not this work?
this is the answer btw:
y=4 * [2^(-2)cos(2*t)ln( abs(cos(2*t))) + t*2^(-1)*sin(2 t)]
if I complexify
I get p(D)y=4/[exp(2ti)+exp(-2ti)]
You appear assume that
Re[1/f]=1/Re[f]
which is untrue
infact
Re[1/exp(2i t)]=cos(2 t)
1/Re[exp(2i t)]=sec(2 t)
Variation of parameters is better for this problem.
thanks a lot! so it means that complexfication is only efficient if i have sines and cosines?
It depends what you mean by complexification. You were using it to try to solve the equation by undetermined coefficients, that can only work when the forcing term can be annihilated by a differentiation operator with constant coefficients. Such functions are sums and products of sin cos and exp.
