Component identification, possibly 'transformer switch'
preston8
I am in the process of reverse engineering an electrical control box for a spa heater, and have stumbled upon a component that I have not encountered before.
Close-up photo of a black contactor with a label reading CONTACT RATING PER POLE, HCCY2XT02AAC, COIL 120 VAC 50/60 HZ, MADE IN CHINA, with a copper coil visible at its base and yellow and blue spade terminals attached.
Two black relay components with white terminal blocks and yellow spade connectors, labelled HCC3XT03AAC and HCC3XT10AAC, mounted on a black panel with red and black wires.
There are two of these components in the system. I was not able to find any information from the part numbers. The coil leads me to believe that this is a transformer. The additional nodes on the sides and the position within the system also lends to a type of switch. Is there such thing as a transformer switch?
Indeed it appears to be a "contactor". I understand what role they play in this system now, thank you.
