Components of The Electromagnetic Field Strength Tensor
The discussion focuses on the derivation and understanding of the radial component of the magnetic field, represented by the equation B_r = g_{11} ε^{01μν} F_{μν}. Participants explore the origins of this equation and its connection to Gauss's flux theorem for magnetic fields, particularly in the context of black holes and magnetic charges. The conversation highlights the relationship between the magnetic field and the electromagnetic field strength tensor, emphasizing the role of magnetic monopoles. Confusion arises regarding the calculation of B_r from the Hodge-dual of the Field Tensor, but clarity is eventually achieved. The thread underscores the complexities of electromagnetic field components and their mathematical representations.
darida
Source: http://gmammado.mysite.syr.edu/notes/RN_Metric.pdf
Section 2
Page: 2
Eq. (15)
The radial component of the magnetic field is given by
Where does this equation come from?
Section 4
Page 3
Similar to the electric charges, the Gauss's flux theorem for the magnetic field gives
const = P/√4π
where P is the total magnetic charge of black hole.
Why does the magnetic charge exist here?
1. You can think of it this way: The magnetic field is part of the space-space submatrix of the Field Tensor.
(The electric field is part of the time-space submatrix of the Field Tensor, as in Eq.12.)
Alternatively, one could say that the magnetic field is part of the time-space submatrix of the Hodge-dual of the Field Tensor.
(From poking around... check out
http://gmammado.mysite.syr.edu/notes/Electromagnetic_Field_Strength_Tensor.pdf )
2. The abstract says that magnetic monopoles are assumed.
Likes darida
Thank you!
Ok now I get confused. So, I am trying to find the radial component of the magnetic field from the Hodge-dual of the Field Tensor, but then end up like this
*F_{\mu\nu}=\frac{1}{2} \epsilon_{\mu\nu\lambda\rho}F^{\lambda\rho}=<br /> \begin{bmatrix}<br /> 0 B_x B_y B_z \\ <br /> -B_x 0 -E_z E_y \\<br /> -B_y E_z 0 -E_x \\<br /> -B_z -E_y E_x 0 <br /> \end{bmatrix}
*F_{01}=B_r=\frac{1}{2} \epsilon_{01\lambda\rho}F^{\lambda\rho}=\frac{1}{2} g_{11}\epsilon^{01\lambda\rho}F_{\lambda\rho}g_{00}
which is different from Eq. (15)
B_r=g_{11}\epsilon^{01\mu\nu}F_{\mu\nu}
What did I do wrong?
Never mind, just found the answer
Likes RRM
Hi Darida, How did you find the answer?
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 18 ·
  • · Replies 59 ·
  • · Replies 51 ·
  • · Replies 0 ·
