Components of Weight on an Inclined Plane
The discussion focuses on the components of weight acting on an object placed on a frictionless inclined plane. The weight components are defined as Wy = -mgcos(θ) and Wx = mgsine(-θ), where θ is the angle of inclination. The sign convention used is arbitrary but must remain consistent throughout the analysis. The participants agree that using the inclined plane's axis for calculations simplifies the problem, as it allows for direct application of trigonometric functions without needing to resolve other forces.
  • Understanding of basic physics concepts, particularly forces and motion.
  • Familiarity with trigonometric functions, specifically sine and cosine.
  • Knowledge of inclined planes and their dynamics.
  • Ability to apply sign conventions in physics problems.
  • Explore the derivation of forces on inclined planes using Newton's laws.
  • Learn about different coordinate systems in physics and their applications.
  • Study the effects of friction on inclined planes and how it alters weight components.
  • Investigate advanced topics such as non-inertial reference frames and their impact on force analysis.
Students of physics, educators teaching mechanics, and engineers working on systems involving inclined planes will benefit from this discussion.
nDever
Hey,
Imagine a frictionless inclined plane situation where the ramp goes up and to the right.
If we put an object on it with any mass m, would it be fair to say that both of the components of the weight are negative? My reasoning is that the x component causes acceleration to the left and the y component presses the object against the ramp (which is downward with respect to the x axis).
The components of the weight would therefore be computed as follows.
Wy= -mgcos(θ)
Wx= mgsine(-θ)
Correct?
You can get those results if you choose a particular sign convention. The sign convention is arbitrary, but you need to be consistent throughout the problem. Your sign convention is perfectly natural-- the x-axis is positive upward and to the right, the y-axis is positive upward and to the left. Any other sign convention would be equally correct, as long as it was clear and consistent.
Note you can also use the traditional vertical y-axis and horizontal x axis, in which case gravity is all in y, but the other forces will need to be analyzed in components. Your way is more convenient.
I have gotten used to using cosine to find the component along the x axis and sine along the y. I was wondering if there were any other methods of finding the components (with the correct sign) of weight on an inclined plane.
Sure, there's any way you want. Just draw arbitrary axes and you're off, if your conventions are consistent then the problem does not care how you draw your axes (although the trigonometric functions you encounter will). Still, there are only two convenient situations-- one where the x-axis is along the inclined plane, and the other where it is along the horizontal (or you can exchange the x and y axes but that's not going to change anything but the labels). Your way is most convenient, because you only have to break up gravity into components, and you usually know gravity already. The other way means you don't have to break up gravity into components, but you do have to break up the forces you don't necessarily know yet, so that's less convenient.
  • · Replies 17 ·
66K
