Which Gas Is Easiest to Compress?
  • Thread starter Thread starter 2112
    Compression
The discussion centers on identifying gases that are easier to compress than air. It highlights that compounds which are vapors at room temperature but have boiling points close to that temperature, such as 1,2-butadiene and butane, are easier to compress. These gases can transition to liquid form under moderate pressure, making them more compressible than air. Additionally, some chlorofluorocarbons (Freons) are noted for their compressibility. Overall, the conversation emphasizes the behavior of gases under varying temperature and pressure conditions.
2112
I was wondering out of all the known gasses, which is the easiest to compress?
Not all gasses compress the same do they?
Lets put it this way, is their a gas that's easier to compress than air?
Any compound that is a vapor at room temperature but has a boiling point near room temperature will be easier to compress than air. 1,2-butadiene, a gas at room temperature and pressure, has a boiling point of about 10C. At room temperature it is almost "compressing" to a liquid by itself. Butane is another example. Butane is so easy to compress that it can be contained as a liquid in a small plastic container (Bic). Some of the Freons (chlorofluorocarbons) are easier to compress as well.
What I have described are compounds that do not behave like an ideal gas near room temperature. At higher temperatures, these compounds behave more like ideal gases although not exactly like them.
Thanks for the lesson, I'm becoming a better and more informed person.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
