Compton Effect, frequency question
An X-ray with a frequency of 3.74 x 10^20 Hz is incident on metal, resulting in a deflected lower frequency X-ray at 48°. The calculations involve using the equations for energy (E = hf) and wavelength (λ = hc/E) to find the frequency of the deflected X-ray. Initial attempts at calculations led to confusion regarding the wavelength and frequency values, particularly due to a calculator setting issue. Ultimately, the correct wavelength was determined to be approximately 1.605 x 10^-12 m, leading to the successful calculation of the deflected X-ray's frequency.
Kennedy111
An X-ray with a frequency of 3.74 x 10^20 Hz is incident on a thin piece of metal. The lower frequency X ray on the other side is observed deflected at 48°. What is the frequency fo the deflected X ray?
fi = 3.74 x 10^20 Hz
Deflected at 48°
I'm not sure... I would guess..
Δλ= (h/mc)(1-cosθ)
E = hf
E = hc/λ
(hc/λ)=hf
I really have no idea where to begin... If someone could just start me off that would be awesome :) This is my attempt anyway..
Ei = hf
= (6.63 x 10^-34 Js)(3.74 x 10^20 Hz)
= 2.47962 x 10^-13 J
E = hc/λ
λ= hc/E
= (6.63 x 10^-34 js)(3.00 x 10^8 m/s) / (2.47962 x 10^-13 J)
= 8.02139037 x 10^-13 m
Δλ = λf - λi
λf = Δλ + λi
= ((6.63 x 10^-34 Js) / (9.11 x 10^-31 kg)(3.00 x 10^8 m/s))(1- cos48) + 8.02139037 x 10^-13 m
=4.78097437 x 10^-12 m
Ef = hc/λ
=(6.63 x 10^-34 Js)(3.00 x 10^8 m/s) / (4.78097437 x 10^-12 m)
=4.16023983 x 10^-14 J
E = hf
f = E/h
= (4.16023983 x 10^-14 J) / (6.63 x 10^-34 Js)
= 6.274871536 x 10^-19 Hz
Yeah... I don't think this is right..
Please help!
Kennedy111 said:
Ei = hf
E = hc/λ
λ= hc/E
x-rays are electromagnetic radiation. So, the easiest way to get back and forth between λ and f is to use the basic wave relation c = λf. Thus, λ = c/f. You can check that this will give the same result for λi.
Δλ = λf - λi
λf = Δλ + λi
Looks set up correctly, but I don't get the same value for λf.
Ef = hc/λ
E = hf
f = E/h
Again, you can just use f = c/λ.
Wait... was your λf value 1.06771397 x 10^-12 ??
My calculator was in radian mode...
I get about 1.605 x 10^-12 m
Hmm... I'm not sure what I'm doing wrong then...
Nevermind! I got it now! :D Thanks :)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
