Computing integral of 3/(x²-4)
20 replies · 5K views · last reply
theakdad
I have to calculate the following indefinite integral. i know that i have to do it with substitution,but here's my problem,im not enough good to do it.
So integral is :
$$\int \frac{3}{x^2-4}dx$$
I would consider using partial fraction decomposition, and then the integration is straightforward.
it would be good if i would know how to do it...
While there is a shortcut (the Heaviside cover-up method), I recommend you use the following since you are new to it:
First, factor the denominator:
$$\frac{3}{x^2-4}=\frac{3}{(x+2)(x-2)}$$
Next, assume it may be decomposed as follows:
$$\frac{3}{x^2-4}=\frac{A}{x+2}+\frac{B}{x-2}$$
Then, multiply through by the denominator on the left to get:
$$3=A(x-2)+B(x+2)$$
Arrange as follows:
$$0x+3=(A+B)x+(2B-2A)$$
Finally, equate corresponding coefficients to get a 2X2 linear system in $A$ and $B$ which you can then solve.
$$3=A(x-2)+B(x+2)$$
Arrange as follows:
What is $A$ and $B$ representing?
They represent constants, such that:
Thanks for that,but as we have done it with substitution,i believe i have to do it so.
Okay, what sort of substitution do you think is appropriate?
lets say $$u=x^2-4$$
Using this substitution, can you get the correct differential?
Re: Integral calculationdz
$$du=2x dz$$ ?
wishmaster said:
$$du=2x dz$$ ?
I assume you mean:
$$du=2x\,dx$$
Can you write the original integral as:
$$\int f(u)\,du$$ ?
If there was an $x$ as a factor in the numerator of the original integrand, you could, but we don't have that. We are going to need another type of substitution...
MarkFL said:
I assume you mean:
$$du=2x\,dx$$
$$\int f(u)\,du$$ ?
Yes,i mean $dx$.
So what kind of substitution do you suggest?
wishmaster said:
Yes,i mean $dx$.
I suggest:
$$x=2\sin(\theta)$$
$$3=A(x-2)+B(x+2)$$
Arrange as follows:
Hello,
basically this problem subsitute Will NOT give you any progress(there MAY be a way with subsitution (but I Dont think so) AND it can take HUGE time to figoure it out, not worth).. As Mark have helped you it's almost done! You got Two equation (linear)
(1)$$A+B=0$$
(2)$$2B-2A=3$$
From the (1) we get that $$A=-B$$ put that in (2) and solve for B and Then solve for A cause you know $$A=-B$$
Regards,
$$|\pi\rangle$$
Petrus said:
Hello,
(1)$$A+B=0$$
(2)$$2B-2A=3$$
Regards,
$$|\pi\rangle$$
Hello Petrus! :D
I do agree that partial fractions is much quicker here, but the OP may not have been introduced to this yet. I know when I took Calc II, we were not introduced to partial fractions until after the various substitution methods, although we had seen partial fraction decomposition in Pre-Calculus, we did not apply it to integration until after substitutions.
This integral is doable with the trigonometric substitution I suggested. :D
Petrus said:
Hello,
(1)$$A+B=0$$
(2)$$2B-2A=3$$
Regards,
$$|\pi\rangle$$
im stuck with it...its for my homework,that i have to give it today,but I am not into integrals very good,so there will be not much points here...
I should take a deep look into books...
MarkFL said:
Hello Petrus! :D
Hello,
Ohh ok i learned it a lot early! Well I actually never done trigonometric substitution on this type! Thanks I learned something NEW!:)
Regards,
$$|\pi\rangle$$
I suggest you do that subsitute as you have not learned the other, if you are interested here is a explain how it works (it's not hard) Pauls Online Notes : Calculus II - Partial Fractions
ps. My phone is about to die so i want be able to help soon..
Regards,
$$|\pi\rangle$$
Regards,
$$|\pi\rangle$$
I will take a look! Thank you friend!
So integral is :
I will now write out a solution using both methods I suggested:
i) Partial fractions:
$$\frac{3}{4}\int \frac{1}{x-2}-\frac{1}{x+2}\,dx=\frac{3}{4}\ln\left|\frac{x-2}{x+2} \right|+C$$
ii) Trigonometric substitution:
$$x=2\sin(\theta)\,\therefore\,dx=2\cos(\theta)\, d\theta$$
$$-\frac{3}{4}\int\frac{2\cos(\theta)}{1-\sin^2(\theta)}\,d\theta=-\frac{3}{2}\int \sec(\theta)\,d\theta$$
$$\sec(\theta)\frac{\sec(\theta)+\tan(\theta)}{\sec(\theta)+\tan(\theta)}= \frac{1}{\sec(\theta)+\tan(\theta)} \frac{d}{d\theta}\left(\sec(\theta)+ \tan(\theta) \right)$$
And so we obtain:
$$-\frac{3}{2}\ln\left|\sec(\theta)+\tan(\theta) \right|+C$$
Back substituting for $\theta$, we obtain:
$$-\frac{3}{2}\ln\left|\frac{2}{\sqrt{4-x^2}}+\frac{x}{\sqrt{4-x^2}} \right|+C= -\frac{3}{2}\ln\left|\frac{2+x}{\sqrt{4-x^2}} \right|+C= -\frac{3}{2}\ln\left|\sqrt{\frac{x+2}{x-2}} \right|+C= \frac{3}{4}\ln\left|\frac{x-2}{x+2} \right|+C$$
