RoyLB said:
Now, to me, the idea of kinetic energy being a "metric" makes sense since it is (typically? always?) a quadratic function of the coordinates, just like the (square) of the distance between two points in Euclidean space.
Well, angular momentum m r^2 \omega is a quadratic function of 'r', but there does not seem to be a way of interpreting that as akin to a metric.
I agree that interpreting kinetic energy as related to a metric is tempting, but I think it's a dead end.The challenge is, I suppose, to capture in words the most general sense of the concept of Energy.
It appears that materials have a state of zero energy, and that energy is accumulated when the material is pushed away from this ground state.
When an elastic material is deformed it stores energy, which is released when the material relaxes again. In elastic deformation the molecules of the material do not slide along each other (when they do slide you have plastic deformation, which dissipates energy). In the case of elastic deformation you are deforming the very molecules away from their ground state.
In a molecular bond there is a distance between the atoms that is the state of least energy. I suppose the most fundamental level of description we currently have is the following: given the quantum physics of molecular orbitals there is a state (of the molecule) that is the most probable. When a molecule is deformed away from that most probable state then it tends to return to the most probable state.
Another aspect: is it possible to view gravitational potential energy as a
deformation away from a state of lowest energy? I think so. According to GR gravitational interaction is mediated by deformation of spacetime. (In other words: spacetime curvature acts as mediator of gravitational interaction.) I infer that when two objects are pulled apart then there is a net increase in spacetime deformation.
Finally, kinetic energy.
When two objects have a velocity relative to each other then that two-object system has the potential to do work.
Example, a electric car that is designed for regenerative braking. When the car and the Earth have a velocity relative to each other then regenerative braking will recharge the batteries. The state of lowest energy is where the two objects have no relative velocity.
So in all I like to think of the relative velocity of the two objects in a two-object system as a form of potential energy.
I don't so much think of the quadratic form, I think of the potential to do work, expressed as force acting over a certain
distance.
What is special of course is that in the case of kinetic energy this potential is realized only at the very instant in time that the two objects actually interact. When two objects interact with each other, and not with other surrounding objects (as in a collision) then they are in effect a two-object system.
