Conceptual question about currents and pumps
The discussion revolves around understanding currents and pressures in the context of pumps and fluid dynamics. The energy density equation is applied to analyze the relationship between pressure, potential energy, and kinetic energy. Participants express uncertainty about whether current remains constant and if velocities differ, leading to confusion about the implications for pressure. One contributor suggests that pressures are equal when measuring at the same height, supporting this with the energy density equation. The conversation highlights the complexities of fluid dynamics and the need for clarity on how different variables interact.
asdf916
I suppose the energy density equation applies here:
(P2-P1) + pg(y2-y1) + 1/2p(v2^2 - v1^2) = Epump/vol - IR
and
I = Av
My initial thought was that the current is the same. But then, since current is Av, I was second guessing myself that maybe the velocities are different. Any help's appreciated!
Also, I'd appreciate it if you guys can help me on these
My guess was that the sewer gas is less than 1 ATM.
My guess is that the pressures are the same. Using the same energy density equation on the first post, I could eliminate the KE, Epump, and IR. That leaves the pressure and the PE. Since it's measuring the same height, the pressure's the same. Is this correct?
19K
