Can Both Hypotheses be Accepted with a Confidence Level of 68%?
  • Thread starter Thread starter cutesteph
    intervals
The discussion revolves around determining a significance level α that allows acceptance of both Hypothesis 1 (E[Y(t)] = 70t) and Hypothesis 2 (E[Y(t)] = 75t) given a Poisson process model with observed calls of 2175 over t = 30. Participants suggest using normal approximation due to the large sample size, noting that the variance of a Poisson distribution equals its expected value. The conversation also touches on the concept of confidence intervals and whether a two-sided test is appropriate for achieving 68% confidence. Ultimately, the goal is to find a method that supports accepting both hypotheses simultaneously. The discussion emphasizes the need for clarity in statistical testing approaches.
cutesteph
1. Homework Statement
Suppose you receive calls that follow a Poisson process model Y(t).
There are two hypotheses, Hypothesis1: E[Y(t)] = λ1t = 70t and Hypothesis 2: E[Y(t)] = λ2t = 75t. Let t = 30 the number of calls be 2175.
Find and compute a significance level α such that both Hypothesis1 and Hypothesis2 are accepted.
2. Homework Equations
α = P( (u - E[Y] /stdY > c / stdY) 3. The Attempt at a Solution
Good question - how are you attempting the problem?
Presumably you've done problems involving confidence intervals and/or poisson distributon before?
Opps, I forgot to type my approach. Since n is big, we can approximate the poisson with the normal.
The variance of a poisson is the same as the expected value.
Or am I suppose to use a two sided test?
Well to 68% confidence limits, would you accept both hypotheses?
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
