Confused about the difference between impulse momentum and kinetic energy
The discussion revolves around a problem involving two masses colliding and the concepts of impulse momentum and kinetic energy. The original poster presents a scenario where mass M1 moves and fuses with mass M2, raising questions about the conservation of momentum versus energy in this context.
  • Participants explore the conditions under which momentum and energy are conserved, particularly in elastic versus inelastic collisions. The original poster expresses confusion about the conceptual understanding of momentum compared to energy.
Some participants have provided clarifications regarding the conservation laws, noting that momentum is always conserved in collisions while kinetic energy is not necessarily conserved. There is an ongoing exploration of deeper understanding regarding the nature of momentum.
Participants acknowledge the complexity of the concepts and express a desire for a more intuitive grasp of momentum, indicating that the discussion is framed within the constraints of a homework help context.
quirck
1 mass M1 of 1 kg moves frictionless at V1 1 meter per second to the right. It fuses with mass M2 of 2 kg and together they keep moving frictionless to the right. What is the speed V2 of the fused objects?
Impulse mass * Velocity
Kinetic energy mass * velocity^2
Conservation of energy 1/2*M1*V1*V1 = 1/2 [Joule] = 1/2*(M1+M2)*V2*V2
V2=SQRT (1/3) [m/s]
Conservation of momentum M1*V1 = (M1+M2)*V2
V2=1/3 [m/s]
My confusion is.
When and why should I conserve momentum and when and why should I conserve energy?
I think I can imagine what is energy of a moving object, however I think that somehow I cannot imagine what is momentum.
quirck said:
My confusion is.
Remember that momentum is conserved in any collision, but kinetic energy is only conserved in some collisions. When the masses bounce apart and energy is conserved, that's called an elastic collision; when they stick together, that's called an inelastic collision (and energy is not conserved).
In this problem, energy is not conserved.
[q]In this problem, energy is not conserved.[/q]
Thank you for the quick reply. Very kind.
I understand you want to stay simple here and this rule of thumb is applicable here, however I want to get a deep understanding of this. Most of all I want to try to get a grasp on what is momentum. Like understanding it so much that even my stomach also understands.
We understand of course that also energy of a closed system is always conserved. So the energy must have gone somewhere. I suspect some kinetic energy was transformed from kinetic to heat or deformation. That would be an answer to the question where the energy would have gone.
But then why is momentum conserved? For me it is still is a rule that is just applied and seems to work in the real world. I have a vivid imagination about how energy is conserved. I just like to have the same vivid imagination about momentum conservation.
Do you have any idea how to explain?
Good!
If you understand that the force on an object tells you the rate of change of its momentum, and you understand that whenever two objects collide they exert equal and opposite forces on each other (as per Newton's 3rd law), then perhaps the fact that total momentum is always conserved in a collision will make more sense.
Read this tutorial: http://www.physicsclassroom.com/Class/momentum/index.cfm"
  • · Replies 22 ·
  • · Replies 16 ·
