Confused by nonlocal models and relativity
The discussion centers around the implications of nonlocal models in quantum mechanics, particularly in relation to Bohmian mechanics and their compatibility with relativity. Participants explore various interpretations and experimental results that challenge or support these models, raising questions about the nature of locality and the predictions of standard quantum mechanics versus Bohmian mechanics.
  • Some participants note that Suarez distinguishes between "decision" at beam-splitters and at detection, suggesting implications for nonlocality and relativity.
  • There is a claim that standard quantum mechanics is a local theory, while Bohmian mechanics is considered to have both local and nonlocal aspects, leading to confusion about their predictions.
  • One participant argues that experiments confirming standard quantum theory also confirm Bohmian mechanics, questioning the validity of Suarez's conclusions.
  • Concerns are raised about the concept of a preferred frame in Bohmian mechanics and its implications for relativity.
  • Participants discuss the "multisimultaneity" model and its attempt to reconcile Bohmian mechanics with relativistic principles, though its clarity and validity are questioned.
  • Some participants express skepticism about the motivations behind ongoing research in Bohmian mechanics, suggesting a disconnect with established quantum theory.
  • There is a request for clarification on how different relativistic versions of Bohmian mechanics might differ in properties and predictions.
Participants express differing views on the compatibility of Bohmian mechanics with relativity, with some asserting that they make the same predictions as standard quantum mechanics, while others argue that this is not the case. The discussion remains unresolved, with multiple competing perspectives on the implications of the experiments and theoretical models presented.
Participants highlight limitations in the clarity of the models discussed, particularly regarding the definitions of locality and relativity in the context of Bohmian mechanics. There are unresolved questions about the assumptions underlying the various models and their experimental validations.
  • #481
Fra said:
I thought discussing in a constructive but critical way the current state of the art theories and in partucular their foundations and was what we did here
Sure, we do that, but your post that I objected to was not that; it was vague handwaving: "perhaps new different thinking is required". As far as I can tell, nobody in this discussion is claiming that our current theories are complete and can never be improved on. So stating that they aren't complete adds nothing to the discussion.
And, as I have said, whatever "new different thinking" might be required is, or will be if it happens, original research, which is not what PF is for. If you have any specific new ideas, you should be doing the original research and getting it published in a peer-reviewed journal; then we can discuss it here. If you don't have any specific new ideas, what point is there in saying you would like some?
  • #482
By this I referred to what neighbourhoods in theoryspace we should or should not include in the search for improvements of our agreed incomplete theories. I felt we should not a priori exclude search areas. And the search areas I suggest are less common, but not totally original. Smolins reference is in that area. We seemed to disagree on which should be included! This is what I meant by "new" thinking. I find it interesting to argue and understand why, based on different types of answers we reject diffetent areas.
/Fredrik
  • #483
Fra said:
Smolins reference
Yes, you've already given it, and that's fine as far as it goes.
However: as you will see if you read the guidelines for this subforum, topics that are discussed in this subforum by their very nature are not resolvable by discussion. That means all such discussions come down to expressions of opinion. And once you've expressed your opinion, it is pointless to keep repeating the same opinion.
Yes, but Smolin himself is still trying to turn this "new thinking" into something actually testable, and he hasn't yet, as far as I know, succeeded. So there's not much more we can say about his paper other than "keep trying". We're certainly not going to carry out the kind of research he is describing here at PF; as I've already said, that's not what PF is for.
  • #484
Using neutron stars and primordial black holes to test theories of quantum gravity​
"Three observational tests of cosmological natural selection, a theory that follows from some hypotheses about quantum gravity, are described. If true, this theory explains the choices of the parameters of the standard model of particle physics. The first, the observation of a pulsar with mass greater than 2.5M∘, would cleanly refute the theory. The second and third, having to do with primordial black holes and early massive star formation, could do so given likely developments in the near future. However given present knowledge these arguments do not presently refute the theory. This shows that cosmological natural selection has not so far been refuted, in spite of being very vulnerable to falsification by possible observations."
-- https://arxiv.org/abs/astro-ph/9712189
Originally he said the estimated limited was 1.6 solar masses, but the exact limite was unclear, he latest increased it a bit. But a heavy pulsar found is: PSR J0952–0607 with 2.35 Solar masses that may or many not falsify smolins theory, I supposed it has to do with the confidence intervals of the limits in the theory as they estimates as they rely on models themselves. There a few papers on this, also with people objecting to the predictions. It is as interesting to read the proponents as the opponents critique.
But the purpose of CNS was not be be the detailed full theory he seeks, it was as I see it just a "example" of how a theory of such type can provide falsifiable predictions. The task of getting an actual theory of this form is clearly extremely hard at least, it's not what the CNS papers are about. So if CNS holds or not does not matter.
A more revent multiauthor paper, Smolin among them from 2021, if someonen wants to discuss any of it, it touches some QM foundational questions for sure, also including another interpretation .
The Autodidactic Universe​
"This paper is one of a growing number that attack the question of why these laws? Why these gauge groups, why these fermion and scalar representations, why the mysteries of chirality, CP violation, and baryogengesis? Why the vast hierarchies of scale and why the particular ratios of parameters of the standard model, setting the values of the masses and mixing angles? It is sobering to contemplate that not one problem of this type has ever been solved, going all the way back to the measurements of the electron’s mass and charge. Roughly speaking, we are faced with a single stark choice:
Either: There are no rational reasons for any of these choices. The universe might have been very different, but there will never be a reason why it took the path we observe it on.
Or: There is at least one rational explanation - in which case we are obligated to find it.
Achieving any of this would be a stunning advance. So it is with trepidation and caution that we mention two more paths these ideas might motivate, each wildly more ambitious than what we have just mentioned. Imagine if we could use the correspondences discussed here to construct learning machines out of the degrees of freedom of gauge and gravitational fields. Perhaps one version of this would be to construct a quark computer which computes using the spins and isospins of quarks and gluons as qubits. But beyond that, the correspondences suggest that the effective degree of freedom of the actual vacuum of a quantum gravity or gauge field might naturally evolve to become an autodidactic learning system. This might be part of the explanation for the choices of gauge fields and representations and values of the coupling constants of the standard model. Since the correspondence organizes a landscape of theories, it might lead to a search
in such a landscape, which might lead to discoveries of note, or might even serve as a model for what the universe might be doing. The results here are tiny, baby steps towards these hypotheses, to be further explored in future work."
-- https://arxiv.org/abs/2104.03902
/Fredrik
  • #485
I can't say much about these speculations, but the problem concerning neutron-star theory is not so much quantum gravity but the quest for the equations of state of strongly interacting matter. We have 2 solar-mass neutron stars and equations of state, which allow for them. So there's no problem with them.
Fra said:
  • #486
I see Smolins CNS as a sample theory "from an interesting category", so the details aren't that important for me (I don't share the specific idea of CNS). But the idea is that the CNS hypothesis as per smolin, predicts that our universe are tuned for "maximal offspring" in number of black holes. And as the fate after a supernova depends on the maximal mass for a neutron star, which supposed relates to finetuning the strange quark mass, he came up with an upper bound. The idea is that there is some gap where it could "in principle" be varied.
"CNS implies a prediction that neutron stars are Kaon-condensate stars and that the upper mass limit for neutron stars is Muml 1.6Msolar[15]. This comes about because the strange quarkmass can be varied to raise and lowerMuml without strongly affecting the processes that lead to massive star formation and supernovas[8]."
-- https://arxiv.org/abs/hep-th/0612185
To the extent a full theory of quantum gravity would help understand things of hypothetical more dense states than neutron stars (quark stars or something else) or explain the mass gap between the smallest observed black holes and the most massive neutron starts is possibly a separate discussion.
Interesting, but not something that I think makes a different for me at aleast about the more general issue the sort of thinking Smolin raises. The issue raised applies not only to QG, but also to just finding a GUT. But I think the evolutionary approache, naturally relates both the high energy limit and the low energy limit; as opposed to have to "fine tune" the high energy limit to get the right low energy limit, which was the issue string theory has had for ages.
/Fredrik
  • #487
Maximum mass limits on neutron stars are not a prediction unique to Smolin's theory. They have been understood to be a prediction of GR plus relativistic degeneracy since the 1930s.
Generally speaking, predictions of this type are not predictions of specific theories but of general frameworks. So observations that refute such predictions, if they were made, would not just refute one particular theory but our whole general framework for understanding gravitationally bound objects. So I don't see this as carrying much weight in terms of falsifiability of Smolin's theory in particular. In this respect his theory is just betting that our current general framework is correct as far as it goes (i.e., it is most likely incomplete and we might at some point discover a more fundamental theory that has our current framework as an approximation in some appropriate limit), which is a pretty safe bet.
When it comes to trying to make more specific predictions that actually are unique to Smolin's theory, what we get is more like this:
The 1.6 solar mass limit was indeed significantly different from the limit predicted by the standard understanding. If we take Shapiro & Teukolsky's classic work from the 1980s as a good example of the standard understanding, it was talking about maximum mass limits for neutron stars in the 2.5 to 3 solar mass range (the uncertainty was mainly due to uncertainty about the exact equation of state for neutron star matter in the relevant density range).
But what actually happened when the 1.6 solar mass limit was refuted? Did Smolin abandon his theory as falsified and go try something else? No, he adjusted the parameters to predict a new limit of 2.5 solar masses, as shown in what I quoted from you at the top of this post. In other words, his theory was not actually making very tight predictions at all; it could be fudged to change the limit from 1.6 to 2.5 solar masses, i.e., from a prediction significantly different from the standard prediction, to one that is indistinguishable from the standard understanding.
In short, I don't share your optimism about this line of research.
  • #488
The main problem is the uncertainty concerning the equation of state of strongly interacting matter. It's a subject of current research in the intersection between particle, nuclear, and astrophysics.
From the nuclear-physics side the investigations are with relativistic heavy-ion collisions as conducted at the LHC, RHIC, and GSI/FAIR. It's not so much about the highest collision energies as at the LHC, where one explores strongly interacting matter under conditions, which are more similar to the very early universe, where one has a (nearly) net-baryon-density free quark-gluon plasma (QGP), undergoing the cross-over transition to a hadron-resonance gas at a time of some ms after the Big Bang. Unfortunately there's no direct observable of this transition left in the cosmic microwave background. So here we indeed rely on the heavy-ion collision data at the highest beam energies available in our accelerators (particularly the LHC). There a blob of a few fermi extension of strongly interacting matter is created for a few fm/c, and one needs many data and a lot of different theorertical models (QCD at finite temperatures, effective hadronic models, relativistic transport theory and hydrodynamics) to analyze these data.
Concerning the phase diagram what's known is not too much. From the theoretical point of view the most is known for the above described LHC/early-universe conditions, i.e., at zero net-baryon density (##\mu_{\text{B}}=0##), where one can directly use lattice QCD at finite temperature to get that there's a cross-over between a (still strongly coupled) QGP and a hadron resonance gas at a pseudocritical temperature of about 160 MeV, and that's confirmed by experimental observations in the sense that the chemical-freezeout conditions that are determined by hadron (and even light anti-(hyper) nuclei!) abundances, which are well described by the statistical hadronization model with indeed a temperature close to 155 MeV and ##\mu_{\text{B}}=0##.
For "neutron star matter" the pendant in heavy-ion collisions is rather at the lower beam-energies, where matter at higher net-baryon density is produced. This is explored particularly in the beam-energy-scan (BES) program at RHIC. Whether or not there is a first-order-phase-transition line with a second-order critical endpoint, as predicted by various effective chiral models, is not yet really conclusive, let alone at which temperatures and ##\mu_{\text{B}}## this might be.
For the neutron stars you have of course also a large isospin chemical potential, because it's "neutron-rich matter", and there are equations of states, that are consistent with all the constraints given by the above described experiments, which allow for the so far predicted large-mass neutron stars (with masses around ## \gsim 2 M_{\text{Sun}})##.
The long-standing puzzle, how to accommodate strangeness with the large neutron-star masses seems also to be close to a solution. The trick is that effective chiral models that realize chiral symmetry in the parity-doublet scheme, where the bulk mass of the hadrons is due to the trace anomaly ("gluonic") and only a small part from the "nuclear ##\sigma## term", which means that at the chiral transition the hadrons do not get massless but only the mass difference between chiral partners vanishes. This also leads to stiffer equations of state, including hyperrons, allowing for the larger neutron-star masses.
Besides the well-known mass-radius relations following from GR + equations of state calculations, there is also the observation of neutron-star-neutron-star collisions and the gravitational-wave signals, which also need the nuclear equation of state (in this case also at finite temperature) as input for corresponding simulations. The highlight was GW170817, where not only the gravitational-wave signal was observed but also the elecromagnetic signals in a wide range of frequencies.
  • #489
Curious about your opinion on these ideas?
Quantum gravity effects on compact star cores​
"Using the Tolman-Oppenheimer-Volkoff equation and the equation of state of zero temperature
ultra-relativistic Fermi gas based on generalized uncertainty principle (GUP), the quantum gravitational effects on the cores of compact stars are discussed. Our results show that 2m(r)/r varies with r. Quantum gravity plays an important role in the region r ∼ 10^3 r_0, where r_0 ∼ beta_0 lp, lp is the Planck length and beta_0 is a dimensionless parameter accounting for quantum gravity effects. Furthermore, near the center of compact stars, we find that the metric components are g_tt ∼ r^4 and g_rr = [1−r^2/(6(r_0)^2)]^(−1). All these effects are different from those obtained from classical gravity. These results can be applied to neutron stars or denser ones like quark stars. The observed masses of neutron stars (≤ 2M⊙) indicate that beta_0 can not exceed 10^37, not as good as the upper bound beta_0 < 10^34 from simple electroweak consideration. This means that incorporating either quantum gravity effects or nuclear interactions, one obtains almost the same mass limits of neutron stars."
-- https://arxiv.org/abs/1110.5550
/Fredrik
  • #490
As the last sentence you quoted notes, these ideas have no significant effect on our estimates of the upper mass limit for neutron stars. This is to be expected since pretty much all possible equations of state for matter in this density regime have already been studied and our estimates of the upper mass limit already take all that information into account. Shapiro & Teukolsky's classic work from the 1980s contains a good review of that research.
  • #491
The equation of state of strongly interacting matter, including in the regime valid for neutron stars/neutron-star merger physics is subject to vigorous current investigation. It's not yet fully understood.
  • #492
In the sense that we don't know its exact form, yes. But we know the range of possibilities well enough to know the range of possible maximum mass limits.
  • · Replies 57 ·
  • · Replies 37 ·
  • · Replies 376 ·
26K
  • · Replies 74 ·
  • · Replies 37 ·
  • · Replies 109 ·
12K
  • · Replies 28 ·
