Confused by variational principle
11 replies · 3K views
madness
My notes give the variational principle for a geodesic in GR:
[tex]c\tau_{AB} = c\int_A^B d\tau = c\int_A^B \frac{d\tau}{dp}dp = \int_A^B Ldp[/tex]
and then apply the Euler-Lagrange equations. By choosing p to be an "affine parameter" where [tex]\frac{d^2 p}{d\tau^2}[/tex] the Euler-Lagrange equations are then expressed as:
[tex]\frac{dL^2}{dx^\mu} + \frac{d}{dp}\left( \frac{dL^2}{d\dot{x}^\mu} \right) = 0[/tex]
where the dot is wrt p. Apparently the affine parameter is usually chosen to be tau, but then L is just 1 and the equation holds trivially! In fact each term in the equation is zero individually. What am I missing here?
In my notes, L is
[tex] \sqrt{g_{\alpha\beta}{x'}^{\alpha}{x'}^{\beta}[/tex]
where the primes are differentiation wrt the affine parameter. Solving the E-L equations for L gives the geodesic equation in terms of the affine param. After that's done, we can substitute [itex]\tau[/itex] for the affine parameter.
Yes that's the same thing, the space-time interval is:
[tex]ds^2=c^2d\tau^2=g_{\mu\nu}dx^\mu dx^\nu[/tex]
which relates our equations. I don't like substituting for tau at the end, since if we had tau at the beginning then L would be constant and each term in the differential equation would be zero individually. It seems like dividing by x then afterwards setting x=0.
I don't see the problem. It doesn't matter what the affine parameter is, the Lagrangian does not disappear.
The problem is that L is defined as:
[tex]L=c\frac{d\tau}{dp}[/tex]
and if p = tau then L=c, a constant. And the each term in the Euler-Lagrange equation is zero individually, which it shouldn't be. In this case any path would satisfy the equations.
So
[tex]L=c\frac{d\tau}{dp} = \sqrt{g_{\alpha\beta}{x'}^{\alpha}{x'}^{\beta}[/tex] ?
Sorry you've lost me. I can't see what you're talking about.
divide both sides by (dp)^2 (not rigourous but that's what my notes say):
[tex]c^2\left(\frac{d\tau}{dp}\right)^2=g_{\mu\nu}\frac{dx^\mu}{dp}\frac{dx^\nu}{dp}[/tex]
denote differentiation wrt p by a dot and take the square root:
[tex]c\frac{d\tau}{dp}=\sqrt{g_{\mu\nu}\dot{x}^\mu \dot{x}^\nu}[/tex]
Are you sure that total derivatives are used?
No.
Consider
[tex]f\left( x, y \right) = x^2 + y^2 .[/tex]
Set
[tex]1 = f\left( x, y \right).[/tex]
Does this mean that
[tex]\frac{\partial f}{\partial x} = 2x = 0?[/tex]
madness said:
So is partial differentiation always assumed to be applied to the unconstrained function?
Yes. In this context, [itex]\partial f / \partial x[/itex] means "differentiate with respect to x while holding y constant". You can't vary x and hold y constant if you are keeping f(x,y) = 1.
The chain rule
[tex]\frac{df}{dp} = \frac{\partial f}{\partial x}\frac{dx}{dp} + \frac{\partial f}{\partial y}\frac{dy}{dp}[/tex]​
relates three derivatives of f, the first along the curve (f=1 in this case), the second if you were to hold y constant, the third if you were to hold x constant. Of course in the case where f is constantly 1 along the curve in question, df/dp would be zero.
madness said:
Is that right? So is partial differentiation always assumed to be applied to the unconstrained function?
Yes, as DrGreg explained.
Have you taken Hamiltonians and Hamilton's equations in a mechanics course? If so, what is the Hamiltonian, and what are Hamilton's equation for a harmonic oscillator? This is a similar application of partial derivatives.
Yes I took a whole course on Hamiltonian dynamics. I assume you're pointing out the constant Hamiltonian whose derivatives wrt p and q are non-zero. I think my problem is that I was very lazy for the first two years of university and only really applied myself when the grades started to count towards my degree. I still have some misunderstandings left over from basic stuff that should be very obvious to me by now.
