Confused - chemical potential of an ideal classical gas
The discussion revolves around the concept of chemical potential in the context of an ideal classical gas, particularly focusing on its behavior with respect to the addition of particles and the implications for energy changes in the system. Participants explore theoretical aspects, mathematical formulations, and conceptual clarifications related to chemical potential, entropy, and energy differences.
  • One participant expresses confusion about the chemical potential being positive when adding particles increases energy, yet it appears negative at higher temperatures, suggesting energy decreases with added particles.
  • Another participant challenges the assumption that adding particles always increases energy, emphasizing the importance of considering other variables like entropy in the equation.
  • A different perspective introduces the Gibbs free energy and discusses how the increase in entropy can outweigh the energy added by new particles, potentially leading to a negative chemical potential.
  • Clarifications are made regarding the definition of chemical potential and its dependence on fixed variables, such as entropy, when considering changes in energy with respect to particle number.
  • A participant shares their background and expresses gratitude for the assistance, indicating they are revisiting university-level physics and seeking clarity on the topic.
Participants do not reach a consensus on the implications of chemical potential, as there are competing views on how energy changes with the addition of particles and the role of entropy. The discussion remains unresolved regarding the conditions under which chemical potential is positive or negative.
Participants highlight the complexity of the chemical potential concept, noting that it can vary based on temperature and the system's entropy. There are references to different formulations and interpretations that may depend on specific conditions or assumptions.
Mireno
Can anyone help me. I am very confused about the chemical potential.
In the following equation
dU = TdS - pdV + u dN, where u is the chemical potential
it seems to me that if you add particles to a system you are increasing the energy of that system, i.e. the chemical potential is positive.
Why is it then that the chemical potential is negative above a certain temperature (as can be seen by taken the derivative of the canonical partition function with respect to the number of particles (times -1/kT))?
This would seem to suggest that as you add particles to a system, the energy of the system decreases!
Why would you say that ?
There's nothing wrong with that.
You can put your "zero" for energy wherever you want, what counts are *differences* in energy (at least in the classical setting where we are in this case).
Consider mechanical potential energy, for instance. Suppose that you put the "0" at floor level. That means that below floor level, in the basement, potential energy is negative. If you add more blocks of lead in your basement, the total potential energy decreases. Nothing wrong with it. With chemical potential, it is the same...
Hi Mireno, welcome to PF. Watch out, you're ignoring the other variables in that equation (most significantly, entropy). And entropy has an increasing influence on system behavior with increasing temperature.
Consider the Gibbs free energy, criterion of spontaneous processes at constant temperature and pressure, defined as G=U-TS+PV. If I add a protruding atom to a formerly flat plane of atoms, for example, the increase in energy could be small compared to the increase in entropy (or rather, TS) because of the many possible equivalent positions of the new atom. The chemical potential \mu=(\partial G/\partial N)_\mathrm{T,P} would therefore be negative for this system. Does this make sense?
What if you use dU = TdS - pdV + udN.
Then u = the partial derivative of U w.r.t. N (WITH S FIXED).
Mireno (aka "Morrie")
It's the same chemical potential:
\mu=\left(\frac{\partial U}{\partial N}\right)_\mathrm{S,V}=\left(\frac{\partial G}{\partial N}\right)_\mathrm{T,P}
In this case, to maintain a constant entropy, you're going to need to cool the system to counteract the entropy of adding the particle. Depending on the magnitude of this entropy, the energy removed via cooling may be larger than the energy added by the particle, which will make the chemical potential negative again.
Mapes (is that your name or a pseudonym?)
Thanks for your help. By way of background, I am a 48 year old revising my university (college) physics - currently 1/2 way through 3rd year. I kept meticulous notes in my university years. This is one problem that has caused me trouble and that I have not been able to nut out using Reif (my text) or the Internet.
I take it that the chemical potential is also used in circumstances where there are different chemical species or where electrical (potential) or gravitational (potential) effects, etc, need to be taken into account.
Again
Many thanks for your help.
  • · Replies 16 ·
