Understanding Compression in Eccentrically Loaded Columns and Beams
The discussion centers on the differences in stress states between eccentrically loaded columns and beams under plane stress conditions. A student questions why moments in an eccentrically loaded column cancel out, leading to uniform compression, while a beam experiences shear stress without uniform vertical compression. It is clarified that stress and strain are not uniform throughout a beam, particularly near load application points. The conversation also touches on the need for advanced modeling techniques, such as finite element analysis, to accurately calculate vertical compression or tension at specific points in a beam. Understanding these concepts is crucial for accurately analyzing structural behavior under various loading conditions.
curiousnoncat
I'm a student taking a non-calculus strength of materials course, and I believe I have what is probably a very simple misconception.
I'm wondering why in the "eccentrically loaded column" b), which has two point loads placed at distances of equal magnitude from a centroidal axis, the moments will cancel each other out, and the cross section will be under uniform compression of a single value, but an element on beam a), which is in a state of plane stress, is not considered to be in compression in the y direction (at least in my textbook).
These seem completely analogous to me, besides the material's dimensions. I've got this sneaking suspicion that compression must exist in the y direction but is "negligible" (would it be negligible in an I-beam?), and also not uniformly distributed.
What is the y direction?
That is an approximation for beams that are much taller than wide (using the orientation of (b) for those words).
By the y direction, I meant the vertical direction on element c, which has no stress indicated.
And what I'm really interested in hearing is a response to that part of the question, about the state of stress in the horizontal beam.
This is again an approximation. Close to the contact points of the forces there will be compression, but you do not have an opposing force on the other side of the beam that would give the usual way of compression. You get shear stress instead.
I think I see where your misconception is. You're thinking of the beam as a static whole.
Notice how there is particular attention paid to element c. This is an attempt to show you that stress/strain is not necessarily uniform throughout an object. Precisely as you surmised.
See http://en.wikipedia.org/wiki/Neutral_axis for a little more information.
Thanks Jack, but I am aware of the derivation for bending stress and the distribution of shear stress in vertical and longitudinal planes, so what I want to know is how you would calculate vertical compression or tension in a beam at an arbitrary point. For example, surely as mfb said, right above actual beam supports there would be compressive stresses approximately equal to the reaction force divided by the area of application.
Well, I would model the system in a 3D CAD tool and run it through finite element analysis...
If you're looking for something more sophisticated, I must leave that to our more erudite fellows.
  • · Replies 23 ·
11K
