Confusion About Oscillating Mass
- Level: High School
- Thread starter person123
- Start date
35 replies · 5K views · last reply
- Air holes turn silicon wafers into flat ultraviolet focusing mirrors for compact optics
- Quantum gas microscope reveals individual atoms in first tunable three-component Hubbard system
- Scientists achieve record-breaking low temperature on China's space station, paving the way for new physics experiments
Homework Helper
- 13,438
- 8,113
Seems simple enough. Finite mass on the piston, rigidly mounted crank-case/engine block. Frictionless bearings and frictionless piston rings. Watch what happens as the mass of the crankshaft and connecting rod decrease toward zero. There is always an increase in crankshaft angular velocity near top dead center and bottom dead center. As the mass of the crankshaft and connecting rod decrease toward zero, the peak angular velocity diverges toward infinity.Nidum said:No need for numbers . Algebra variables are what we will use . We can keep the actual maths quite simple .
There is no convergence toward a physically reasonable limiting behavior. Something will break first.
person123
- 326
- 52
All right. My train of thought before making the thread was this:jbriggs444 said:Seems simple enough. Finite mass on the piston, rigidly mounted crank-case/engine block. Frictionless bearings and frictionless piston rings. Watch what happens as the mass of the crankshaft and connecting rod decrease toward zero. There is always an increase in crankshaft angular velocity near top dead center and bottom dead center. As the mass of the crankshaft and connecting rod decrease toward zero, the peak angular velocity diverges toward infinity.
I know that when the mass is momentarily still, the acceleration is at its maximum. I can find that acceleration, and then find what the angular acceleration would be at that point. This would allow me to find the maximum torque. It did give me an equation (τ=ω^2l^2m) which passes dimensional analysis and seems reasonable, but I never considered the mass of the rod. Does this calculation make any sense to do, or should I go back to the drawing board completely?
person123
- 326
- 52
Also what is exactly meant by:
What is meant by something breaking? Is this meant in a physical sense?jbriggs444 said:There is no convergence toward a physically reasonable limiting behavior. Something will break first.
Homework Helper
- 13,438
- 8,113
How are you going to manage infinite acceleration with a material with a finite strength to mass ratio?person123 said:Also what is exactly meant by: What is meant by something breaking? Is this meant in a physical sense?
person123
- 326
- 52
I see what you meant.jbriggs444 said:How are you going to manage infinite acceleration with a material with a finite strength to mass ratio?
- huginn
- · Replies 6 ·
- Astronomy, Astrophysics, Cosmology
- Replies
- 6
- LogarithmLuke
- · Replies 4 ·
- Mechanics
- Replies
- 4
High School
Some confusion about balanced forces
- ViolentCorpse
- · Replies 4 ·
- Mechanics
- Replies
- 4
