Confusion regarding the coefficient of restitution
The coefficient of restitution (e) has two definitions: e = final relative velocity / initial relative velocity and e = √(final KE/initial KE). In a perfectly inelastic collision, the first definition yields e = 0, while the second yields e = 1/√2, leading to confusion. The discussion highlights that a coefficient of 0 does not necessarily indicate a perfectly inelastic collision, and emphasizes the importance of measuring kinetic energy in the center of mass frame. Additionally, the use of relative speed versus relative velocity is debated, with a suggestion that definitions may vary across texts.
  • Understanding of the coefficient of restitution in physics
  • Knowledge of kinetic energy and its calculations
  • Familiarity with collision types: elastic and inelastic
  • Concept of center of mass in physics
  • Research the implications of the coefficient of restitution in different types of collisions
  • Study the center of mass frame and its relevance to kinetic energy measurements
  • Explore examples of collisions with a coefficient of 0 that are not perfectly inelastic
  • Investigate the differences between relative velocity and relative speed in collision analysis
Physics students, educators, and professionals in mechanics or engineering who seek to deepen their understanding of collision dynamics and the coefficient of restitution.
parsesnip
I learned that there are two different definitions for the coefficient of restitution: e = final relative velocity / initial relative velocity and e = √(final KE/initial KE). However, I don't understand how these two definitions will always give the same value.
If one particle with mass m moving with velocity v has a perfectly inelastic collision with another particle of mass m at rest, then both will move together with the velocity v/2. According to the first definition, e = 0 as the final relative velocity is 0. However, according to the second definition, e = √((1/2(2m)(v/2)2)/(1/2mv^2)) which is 1/√2.
Also, Wikipedia says that "A perfectly inelastic collision has a coefficient of 0, but a 0 value does not have to be perfectly inelastic.". Can someone give me an example of a collision with a coefficient of 0 that is not perfectly inelastic? I thought that was the definition of perfect inelasticity.
Also shouldn't the first definition use relative speed instead of relative velocity? For example, if a particle of mass m hits a wall with velocity v, it will rebound with velocity -v, so according to this definition e should be -1.
If you are measuring velocities from the frame of reference where the particles end up together at rest, it is only fair to measure kinetic energy in the same frame. In that frame, final kinetic energy is zero.
The coefficient of restitution is properly measured using energy in the center of mass frame.
parsesnip said:
I learned that there are two different definitions for the coefficient of restitution: e = final relative velocity / initial relative velocity ...
Unless you have a definition wher e is negative, I think it is always |e| = - (final relative velocity)/(initial relative velocity)
<Edit: provided relative velocity is defined exactly the same both before and after. Most texts seem to define them in the opposite sense, which explains why they get both having the same value <edit2: sign rather than value>.>
As far as I can see, it doesn't matter whether one object is a brick wall or another small object, whether one is stationary or both moving, the relative velocity always changes sign.
<Edit: speed would not be useful for the definition, except in one dimension.>
The rest I'm still jugging with!
107K
  • · Replies 53 ·
