What Are the Force Components and Radial Acceleration in a Conical Pendulum?
The discussion focuses on calculating the force components and radial acceleration of a conical pendulum with a 78.0 kg bob suspended by a 10.0 m wire at a 5.00° angle. The tension in the wire was calculated to be 761.491 N, with the horizontal component determined to be 66.3683 N using the formula Tsin(θ). The radial acceleration was derived as 0.851 m/s², correcting earlier miscalculations. The participants clarified the distinction between force and acceleration, emphasizing the importance of proper unit application in physics problems.
  • Understanding of Newton's laws of motion
  • Knowledge of trigonometric functions in physics
  • Familiarity with centripetal acceleration concepts
  • Ability to perform vector decomposition of forces
  • Study the derivation of tension in conical pendulums
  • Learn about vector decomposition in physics
  • Explore the relationship between angular motion and radial acceleration
  • Investigate the application of trigonometric functions in force calculations
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors seeking to clarify concepts related to pendulum motion and force analysis.
pcandrepair
Consider a conical pendulum with a 78.0 kg bob on a 10.0 m wire making an angle of θ = 5.00° with the vertical. (Consider positive i to be towards the center of the circular path.)
(a) Determine the horizontal and vertical components of the force exerted by the wire on the pendulum.
________N i + _________N j
(b) What is the radial acceleration of the bob?
________m/s^2
a = v^2 / R
I found the vertical component of the force:
\SigmaFy = Tcos(5) - 78(9.8)
T = 78(9.8)/Cos(5)
T = 761.491 N
To find the horizontal component wouldn't you need to find the acceleration(part b) first?
I used the following to find the velocity:
\SigmaF(radial) = -Tsin(5) = -m(v^2 / R)
v^2 = R*Tsin(5) / m
using trig and the given 10m wire length i found the radius to be .871557m
v^2 = .871557(761.491)(sin(5)) / 78
v = 7.60551 m/s
Then i plugged that into the acceleration equation given in the relevant equations section but it was 66.3683 m/s^2 which does not sound reasonable for this problem.
Any suggestions on what i did wrong?
Going back to v^2 = R*Tsin(5) / m
to find angular acceleration, one simply takes v2/r = T sin(5)/m
or 762 N * (0.08716) / 78 kg = __________
Ok, I found the acceleration to be .851m/s^2. Now, to find the horizontal component of the force i would set that acceleration equal to T*Sin(5)?
Tsin(5) = a
T = .851 / sin(5)
T = 9.764 N ?
The tension was correctly calculated.
With a = v2/r = T sin(5)/m
one obtains 762 N * (0.08716) / 78 kg = 66.42 N/ 78 kg = 0.85 m/s2
I think in the OP, one simply forgot to divide by 78.
I entered 9.764 N for the horizontal component of the tension force and it said it was incorrect.
Tsin(5) = a
is not correct. T is a force, a is an acceleration. There has to be a mass associated with a.
Let T = 762 N and the horizontal force is T sin(5).
You calculated the tension correctly in your first post. Just find the horizontal component of that, since you have the angle.
You don't need to use the centripetal acceleration formula for this problem.
so, the horizontal component of 761.491 N would be sin(5)*761.491 which equals 66.3683 N
Yes.
Alright, I get it now. Thanks for your help Astronuc and Doc Al!
  • · Replies 20 ·
