Conjugate of αe^(iα) when α is complex
  • Level: Undergrad
  • Thread starter Thread starter dyn
    Complex
20 replies · 3K views
dyn
Member warned that homework or textbook-style questions must be posted in the Homework sections
Hi. If I have a complex number αe iα where α is complex what is the conjugate ? Usually I just replace i with -i but do i also take the conjugate of all α's ?
Thanks
There are rules how to take the complex conjugate of a product of complex numbers, for example. If you don't know the rules you can look them up or derive them yourself (e.g. by writing ##\alpha = \beta+i \gamma## with real ##\beta## and ##\gamma##).
I get the complex conjugate of αe i α as α*e- i α*
Is that right ?
dyn said:
Is that right ?
Not quite. Replacing ##e^{i\alpha}## by ##e^{-i\alpha}## only gives the conjugate if ##\alpha## is real. Try writing ##\alpha=b+ic## and then work out the conjugate of ##e^{b+ic}##.
Or directly find the complex conjugate of ##e^{i(b+ic)}##
I want to emphasize this is not homework. I self-study at home. I do not get homework.
I don't think my previous answer was very clear. So I will try again. I think the complex conjugate of zeiz is z*e-iz*.
Is that correct ?
Thanks
Even if you are not in a formal class, if the problem is from a textbook or is a textbook-style problem, it should be posted in one of the Homework & Coursework sections, not here in the technical math section.
Is that correct ?
Thanks
Could somebody please tell me if my answer is correct for the complex conjugate ?
I have replaced iz in the exponential by - i times the conjugate of z. If that is not right can someone please tell what the right answer is ?
conjugate of ea+ib is ea-ib
conjugate of ei(a+ib) is e-i(a-ib)
So the conjugate of eiz is e-iz* ?
So all i's are replaced by -i and and all complex numbers by their complex congates ?
What is the simplified form of the last expression above?
It is not. Consider a=0, b=1 for example.
Edit: See below.
If a=0 and b=1 then ei(a+ib) is a real number e-1 so the number and its complex conjugate are the same. I have no idea why I keep being told I am wrong. Can someone please tell me what the complex conjugate of zeiz is ?
One of the properties of the complex conjugate (alluded to in post #2) is that ##\overline{zw} = \bar z \cdot \bar w##.
So, ##\overline{ze^{iz}} = \bar z \cdot \overline{e^{iz}}##
Although ##\overline{e^{ia}} = \overline{e^{-ia}}## if a is real, this formula isn't applicable if a is a complex number. As already suggested, replace z in the expression ##e^{iz}## by a + bi, and find the conjugate of ##e^{iz}##.
I think that your answer is correct. Setting z = a +ib where a & b are real, I get:
(ei(a+ib))* = e-be-ia
and
e-i(a+ib)* = e-be-ia
So (eiz)* = e-iz*
Using this in your problem gives your result.
I got an answer from a lecturer at a top university who told me just replace i with -i and z with z* which is what i had been saying all along. I'm not sure why some people disagreed with this
mfb said:
Sorry, I missed a minus sign in your previous post.
Your answer is right.
Thank you. I was beginning to think I was going mad !
My initial reaction was that there could not be an identity that simple that was not well known. I was surprised by it. That is probably why most people, including myself, assumed that it was not true.
