What Is the Distance Traveled by a Disc on a Block Before Coming to Rest?
The discussion centers on calculating the distance traveled by a 0.2 kg disc on a rough 1 kg block before coming to rest. The disc slides down from a height of 1.8 m, reaching a velocity of 6 m/s upon impact. Using conservation of linear momentum, the velocity of the block is determined to be 1 m/s. The calculations yield a distance of 2.41 m, but discrepancies arise in the time calculations for both the disc and the block, indicating potential errors in the initial assumptions or calculations.
  • Understanding of conservation of linear momentum
  • Familiarity with kinematic equations
  • Knowledge of frictional forces and their effects on motion
  • Basic principles of energy conservation in mechanics
  • Review kinematic equations for motion under constant acceleration
  • Study the principles of energy conservation in mechanical systems
  • Learn about frictional forces and their impact on motion
  • Explore detailed examples of momentum conservation in collisions
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of momentum and energy conservation in real-world applications.
chingcx
A 0.2 kg disc slides down from smooth track of height 1.8m. It arrives at a rough 1 kg block resting on a smooth surface. The friction between them is 1.2N. Find the distance traveled by the disc on the block before it comes to rest relative to the block.
use observer frame:
velocity=6 m/s
then I use conservation of linear momentum, because only internal forces.
m1u1=m1v1+m2v2
0.2(6)=1.2(v)
v=1 m/s
f=1.2N to right on the block, to left on the disc
a of disc=-6m/s^2
a of block= 1 m/s^2
for the disc, v^2-u^2=2as
-35=2(-6)s
s=35/12 m
for the block,
1=2(1)(s)
s=0.5 m
so it moves 2.41 m on the surface
but when I find the time required
for the disc, v=u+at
1=6+(-6)t
t=5/6 s
for the block
1=0+(1)(t)
t= 1s
They are different?
I know my answer of 2.41 m must be wrong, but where is my mistakes?
thank you!
Hi chingcx! :smile:
m1u1=m1v1+m2v2
0.2(6)=1.2(v)
v=1 m/s
I don't follow this: it's not an impulsive collision :confused:
a of disc=-6m/s^2
a of block= 1 m/s^2
Correct method, but check your figures.
for the disc, v^2-u^2=2as …
I'm not sure what you're doing here.
You can either use v2 = u2 + 2as for each body, and find what s gives the same v,
or (especially since it seems they want you to use conservation) you can use change in energy = work done (1/2 m v2 = 1/2 m u2 + Fs), which amounts to the same thing (and they give you F anyway, plus this avoids working out what a is) :wink:
