Conservation of momentum (extremely easy but confusing)
The discussion centers on a homework question regarding the relationship between mass and momentum, where the mass of an object increases. Participants express confusion over the phrasing of the question, noting that without information on velocity, it's impossible to determine how momentum changes. The consensus is that the question is poorly worded, leading to potential misinterpretation of the correct answer. One participant suggests that option C (sometimes increases, sometimes decreases) would be the most reasonable choice, though it was marked incorrect. Overall, the thread highlights frustrations with ambiguous questions in physics.
avenkat0
If the mass of an object increases, its momentum
A. always increases
B. always decreases
C. sometimes increases, sometimes decreases
D. sometimes decreases, never increases
E. sometimes increases, never decreases
MV=momentum
I figured if one of the variables increased the whole would increases but it turned out to be wrong.
Then if the velocity changed with the mass momentum would remain the same. but that choice is nowhere to be found.
Thank you
In my opinion, the question in itself is poorly worded as we have no information regarding the velocity. However, since we have no information on the velocity, we have no way of knowing if the momentum will increase or decrease so I would have to say C.
Turned out to be wrong... :( that was my last shot.
Thats such a bad question... is any other answer possible?
The question clearly has been phrased in a horrible way, I agree with Hoot. A smart student should answer c), a not so smart student will probably answer a) and might even get it "correct." Where did you get this question?
