Conservation of Momentum in an Inelastic Collision
The discussion revolves around calculating the minimum initial speed of a bullet required for a pendulum bob to complete a vertical circle after the bullet passes through it. The conservation of momentum is applied to determine the velocity of the pendulum bob immediately after the bullet exits, with the bullet emerging at half its initial speed. The key point is that the pendulum must have zero velocity at the top of its swing to barely complete the rotation, leading to the need for energy conservation equations to relate the pendulum's speed before and after the collision. The final equations derived show that the initial speed of the bullet can be expressed in terms of the pendulum's height and gravitational potential energy. The discussion concludes with a consensus on the importance of understanding energy loss and momentum conservation in solving the problem.
tseryan
A bullet of mass m and speed v passes completely through a pendulum bob of mass M. The bullet emerges with a speed of v/2. The pendulum bob is suspended by a stiff rod of length L and negligible mass.
What is the minimum value of v such that the pendulum bob will barely swing through a complete vertical circle.
Basically, what occurs is a bullet m is shot through a mass M which is suspended by a rod and pinned on the wall (it pivots in a circle). The problem asks for the minimum value of v so that M will spin in a circle once if the bullet emerges with a speed of v/2.
m1v1+m2v2=m1v1'+m2v2'
Maybe a work/energy equation?
I understand that the momentum of the bullet is transferred to the pendulum which is why the pendulum swings around and the bullet leaves with half the velocity it entered with, but I don't know how to find the amount of energy it takes to spin the pendulum.
Any help would be greatly appreciated.
Do you know what that statement means?
It means that the pendulum swings around in an perfect circle (it stops exactly where it starts).
Yes, but it can swings with different velocities. What would be the minimum one, at the upper vertical position?
P.S. Actually the pendulum never stops!
I don't think it uses the equation I listed above with a set velocity. They give me L (the radius of the spin), which leads me to believe that I need to calculate the work done by the pendulum in the spin (W=FD and d is 2Lpi (circumference), but I'm not sure about force) and correlate the work done to the energy lost by the bullet when it leaves the pendulum. Also, there really is no displacement, so I'm not sure if I can even use the work equation for that.
What do you mean by the pendulum never stops? I'm assuming there is gravity even though they don't mention it.
You don't have to use a set velocity in the conservation of momentum!
But you do have to understand from the problem's statement that the pendulum must have zero velocity in the upper vertical position.
That's why it states minimum and barely.
Are you sure? I understand a=0 at that point, but the pendulum is moving the entire rotation.
You are asked to calculate the minimum value, so think like this.
Let A be the point where the collision took place and let B the upper point.
In order for the pendulum to make the entire rotation it must reach point B. The velocity of M at B depends from the velocity at A, v_B increases if increases. Thus if you find the v_A in order v_B=0, then you can say that this v_A is the mimimum one, in the sense that every velocity above that ensures that the pendulum makes an entire rotation.
P.S. At point B the accerelation is not zero.
Ohhh, I'm sorry if I incorrectly explained the problem, but the bullet is traveling at v and it asks for the minimum speed of the bullet as it passes through the pendulum in order for the pendulum to go around one rotation.
:smile: My English are pretty poor! I will try again to explain.
  • From the conservation of momentum you can find the velocity V_A of M, in terms of the velocity v of m.
  • From the conservation of energy for the mass M, from A to B, you can find the velocity V_B in terms of V_A, i.e. in terms of v.
  • Now demanding V_B=0 in order the pendulum barely swings you can calulate v.
Does it makes any sence?
Doesn't Va of M is equal to zero since the pendulum is initially not moving? I don't quite understand what to do when the initial and final velocities of an object is zero, but it moves in between that period.
Mass M:
Velocity before collision zero
Veloity after collision V_A not zero! (zero at point B)
Mass m:
Velocity before collision v
Velocity after collision v/2
Can you find V_A from the conservation of momentum?
Ahhhh, I simply solve for the variable Va. Let me try that! :) I really appreciate your help Rainbow Child.
Ok! The equation you wrote (conservation of momentum) reads
p_{initial}=p_{final}\Rightarrow m\cdot u+M\cdot 0=m\cdot \frac{u}{2}+M\cdot V_A
so you have for V_A ...
Correct, that is what I have. I solved for Va and got Va=mv/2M. I'm not sure what to do after this. How would I find Vb and v from this?
Now write the conservation of energy for M, from the point A to the point B, to calculate V_B in terms of v.
I don't quite understand. Is that the 1/2mv^2 equation?
The conservation of energy is
Potential EnergyA+Kinetic EnergyA=Potential EnergyB+Kinetic EnergyB (1)
For mass M,
PE_A=0,\, KE_A=\frac{1}{2}\,M\,V_A^2,\,PE_B=M\,g\,2\,L,\, KE_B=0
Plug the above values in (1) in order to find V_A
I just solved for Va and got sqrt(2gL) (the mass canceled out). This equation gives me the speed of if the pendulum before the collision. I also have the speed of the pendulum after collision, which I found earlier from the conservation of momentum equation. Is this correct?
Oupps! My mistake! PE_B=M\,g\,2\,L. The mass M is at height 2\,L.
Now equate the two results for V_A in order to find v.
Ahhh! I should've caught that mistake. I now have Va=sqrt(4gL). I understand how to get v, but I am still unclear why mv/2M and sqrt(4gL) are equal? Are they just two different ways to write Va?
We have computed V_A by two ways.
The velocity V_A is the final velocity of M after the collision, and simultaneously is the initial velocity for the movement of the pendulum.
Ah, everything finally makes sense now. I re-read everything you've said and it's all very clear now. :)
Thanks again Rainbow Child! You're a physics genius! I extremely appreciate you sticking with me the 3 or so hours it took for me to complete this fairly simple problem.
Every problem fails to the category "fairly simple problem" when it is solved! :smile:
Glad I helped! :smile:
Why don't you get the right answer if you only use conservation of energy->
initial KE = final KE + final U
\frac{1}{2} mv^2 = 2LMG + \frac{1}{2} m(v/2)^2
I think maybe you cannot use it because energy is lost (i.e we are not counting heat). Is this correct?
hey guys cud you tell if momentum,kinetic energy, potential energy, total energy and nucleon number conserve in nuclear reaction
