Conservation of momentum in compton scattering
Momentum conservation in Compton scattering is a vectorial concept, meaning it must be considered in terms of its components rather than absolute values. The feedback received highlighted that momentum is conserved componentwise, which necessitates treating all momenta as vectors. When analyzing such collisions, it's crucial to break down the momentum into its x and y components to ensure accurate calculations. Using absolute values alone can lead to incorrect conclusions, as the magnitude of the sum of vectors does not equal the sum of their magnitudes. Understanding the directional aspects of momentum is essential for solving problems in this context.
Avatrin
Hi
I recently got some weird feedback on homework. It said that "..momentum is only conserved componentwise..". The problem involved Compton scattering, and I had used p_{\lambda,1} = p_{e,2} + p_{\lambda,2} to find p_{e,2} for collision between an electon and a photon. I had used the absolute values for the momenta because that was all I had.
So, in the general case, how is momentum conserved? Also, in the specific case, how should it be used in problems like the one above?
Science news on Phys.org
The feedback is a little confusing. Especially the "only" part.
It's not that it does not conserve otherwise but the momentum is a vector and so the conservation law is a vector expression.
So in your expression above, all three terms should be vectors. Then you can split it by components - this is what they say.
If you want to look at the absolute values, than you should realize that the absolute value of the sum of two vectors (as yo have on the right-hand side) is not the sum of the absolute values. So the equation does not hold as you wrote it, if these are absolute values.
Momentum is a vector quantity, so what is conserved is a vector. The sum of the magnitudes may not be conserved. If you only have the magnitudes then you don't really have enough information. You also need to know the directions to use momentum.
EDIT: and its nasu for the win!
More explicitly, you should have started with $$p_{\lambda,1,x} = p_{e,2,x} + p_{\lambda,2,x} \\ p_{\lambda,1,y} = p_{e,2,y} + p_{\lambda,2,y}$$ For convenience, we usually choose the coordinate system so the incoming photon enters along the x-axis which makes ##p_{\lambda,1,y} = 0##. You don't need to consider a third component because the three vectors define a plane.
Likes Avatrin
Thank you all!
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
