Understanding the Constant Field of a Differential Field in $k((x))$
In summary, the constant field of the differential field $k((x))$ is $k((x^p))$ and its functions are those that are zero under differentiation. In characteristic zero, this field is simply $k$, but in characteristic $p$, the monomial $x^p$ differentiates to zero. This means that if $f$ is a solution to a linear differential equation, then $x^pf$ will also be a solution.
mathmari
MHB
5,049
Hey! :eek:
I am looking at the following part:
View attachment 5078 The constant field of the differential field $k((x))$ is $k((x^p))$.
Hence if $(1)_p$ has a solution in $k((x))$, multiplication by a suitable constant yields a solution in $k[[x]]$. What exactly is a constant field of a field? (Wondering)
Here, they almost surely mean the "functions" in $k((x))$ which are zero under differentiation. In characteristic zero, this would just be $k$, but in characteristic $p$, the monomial $x^p$ differentiates as
\[\frac{d}{dx}x^p = px^{p-1} = 0x = 0.\]
One consequence of this observation is that for any $f(x) \in k((x))$, then
\[\frac{d}{dx}x^pf = px^{p-1}f + x^p \frac{d}{dx}f = x^p\frac{df}{dx}\]
which means that if $f$ is a solution to a linear differential equation, then $x^pf$ will also be a solution to the same equation.
What is a constant field?
A constant field is a region in space where the value of a physical quantity, such as electric or magnetic field, remains constant at every point.
How is a constant field created?
A constant field can be created by placing two oppositely charged objects close to each other, or by using specialized equipment such as capacitors or magnets.
What are the applications of constant fields?
Constant fields have various applications in physics, engineering, and everyday life. They are used in electronic devices, particle accelerators, medical imaging, and many other fields.
Can a constant field exist in nature?
Yes, constant fields can exist in nature. For example, the Earth's magnetic field is approximately constant at the surface of the planet, and the electric field in a parallel plate capacitor is constant between the plates.
How is a constant field different from a changing field?
A constant field has a fixed value at every point, while a changing field's value varies at different points in space or time. Additionally, the equations that describe the behavior of a constant field are simpler and easier to solve compared to a changing field.
  • Linear and Abstract Algebra
