Continuity and Differentiability of Piecewise Defined Functions
2 replies · 2K views
ryu1
I have this problem I haven been trying to solve for a while:
"Check if the following function is continuous and/or differentiable :"
/ (x^2-1) /2 , |x|=< 1
f(x) = \ |x| -1 , |x| > 1
So I managed to prove it is continuous for all x by checking the limits as x -> 1 from both directions = 0
and the limit as x -> 0 from both directions = -1/2 (is that necessary?)
from that point it's continuous for all x as a polynomial in either branch.
is that correct so far?
now the problem starts with the derivative check...
I get that the f'(x) = x , |x| < 1
or f'(x) = x/|x| , |x| > 1
so does that alone means the function isn't differentiable in x = 0 ?
Thank you for your help!
You also need to check at x = -1
No. It is a polynomial there.
There is no problem at x=0. The problem is at x = 1 and -1 where the two functions piece together. You need to check the function values and slopes there.
THANKS a lot you helped me solved this at last!
