Continuous fractions for root 2
The discussion focuses on proving the continued fraction representation of √2, expressed as √2 = 1 + 1/(2 + 1/(2 + ...)). Participants clarify the terminology, noting that "continued" fraction is the correct term. The conversation involves algebraic manipulation, specifically transforming the expression x = 1 + 1/(2 + 1/(2 + ...)) to derive a relationship involving x. The participants confirm that the transformation leads back to the original expression, illustrating a common mathematical technique. Overall, the thread emphasizes the process of proving the continued fraction representation of √2.
bgwyh_88
Hi all,
Could anyone guide me on the following prove
√2 = 1+1/(2 + 1/(2+ 1/(2+ 1/(2+···))))
Mathematics news on Phys.org
Hi bgwyh_88! :smile:
Let
x=1+\frac{1}{2+\frac{1}{2+...}}
Then what is \frac{1}{x-1}-1?
By the way, the term in English is "continued" fraction, not "continuous" fraction.
Let
hey micromass,
You will ultimately get
1+ \frac{1}{2+\frac{1}{2+...}}
Where did you get
\frac{1}{x-1}-1 from?
bgwyh_88 said:
hey micromass,
Yes, and that is x. So \frac{1}{x-1}-1=x
Where did you get
You just need to transform x to something that equal x again. It's a standard trick that you had to see once...
micromass,
Cool. Thanks mate. :approve:
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
