Continuous linear transformation
Andy_ToK
T is a linear transformation from R^m->R^n, prove that T is continuous.
I have proved that there's always a positive real number C that |T(x)|<=C|x|. How shall I proceed then?
Thanks~
May I ask how you have shown that?
x is an element of R^m
|T(x)|=|sum_i(xi*T(ei))|<=sum_i{xi(|T(ei)|)}
let A=max{|T(e1)|,|T(e2)|...|T(em)|)
then |T(x)|<=A*sum_i(xi)<A/sqrt(m)*sqrt(sum_i(xi^2))=A/sqrt(m)*|x| (AM<RMS)
sorry, i don't know how to use latex here:frown:
1) You forgot an absolute value sign around xi in line 2:
|T(x)|=|sum_i(xi*T(ei))|<=sum_i{|xi|(|T(ei)|)}
2) How did you get
sum_i|xi|<[1/sqrt(m)]*sqrt(sum_i(xi^2)) ?
Surely this is not true. Take for instance the case when all but one of the x_i are non-vanishing. The inequality becomes
|xi|<[1/sqrt(m)]*|xi| <==> sqrt(m)<1You had good ideas in your attempt but I suggest working directly with the definition of continuity. Given e>0 and x0 , try to find a d>0 such that |x-x0|<d ==> |T(x)-T(x0)|<e.
Well, can you show that it is Lipschitz?
2) How did you get
1.Thanks for pointing that out, it should be the absolute value.:smile:
2.sorry i made a mistake there, it should be
sum_i|xi|<sqrt(m)*sqrt(sum_i(xi^2)) by AM<RMS
Here is the standard way of doing it:
For any linear transformation we define the norm of it as ||T||=\sup_{|x|&lt;1}|T(x)|. Your arguments show that this norm always exists for any linear map.
Then we have |T(x-y)|\le||T|||x-y|. Therefore T is Lipschitz, hence uniformly continuous. If you don't know anything about Lipschitz and uniform continuity you can just let |x-y|&lt;\epsilon/||T|| and we have our desired result.
Oh, ok. I did not know this inequality, but it is true as long as you change that < for a <=, because obviously for m=1, we have an equality. What does AM and RMS stand for?
What you've proven in showing |T(x)|<=C|x| is that T is Lipschitz continuous at 0. Usually, we say that a function f is Lipschitz at x0 if there exists numbers c and M such that |x-x0|<c ==> |f(x)-f(x0)| \leq M|x-x0|. A function that is Lipschitz is necessarily continuous because given e>0, choose d=min{c,e/M}.
So, can you extend your result and show that T is Lipschitz everywhere?
ZioX said:
Then we have |T(x-y)|\leq ||T|||x-y|.
Shouldn't there be a sqrt{m} also on the RHS as in Andy's AM<RMS?
oops, it should be <=, thanks.
AM=arithmetic mean
RMS=root mean square AM<=RMS (the equality holds when |x1|=|x2|...=|xm|)
Thanks quasar987 and ZioX
I forgot to use T(x)-T(y)=T(x-y) for the linear transformation...
let d=e/C then, |x-y|<d --> |T(x)-T(y)|=|T(x-y)<cd=e
I'll explain the logic a bit.
Define ||T||=\sup_{|x|&lt;1}|T(x)|.
Now the previous argument shows that there exists a C such that |T(x)| \le C|x|.
Now, if we restrict |x| &lt; 1 we get |T(x)| \le C|x| &lt; C so that |T(x)| has an upper bound, hence a supremum.
Now, for continuity, it just becomes a matter of verifying that 0 \le |T(x)-T(y)|=|T(x-y)|&lt;\epsilon whenever 0 \le |x-y|&lt; \min\{\epsilon / ||T||,1\}.
