Contraction transformation proof
12 replies · 4K views
charmmy
1. Homework Statement
Q1) Show that a contraction transformation from V to V has a diagonal matrix representation regardless of the basis given to V (same basis in domain and range).
!2) T(x1,x2,x3)=(x1,x2,x2*x3) find the kernel and range T for this transformation.
2. Homework Equations
3. The Attempt at a Solution
Q1)how do we go about building a matrix representation? just arbitarily orr?? Where should I even start?
Q2) the transformation is not linear, so we can't actually find an Echloen matrix to row reduce?
You've seen the problem correctly. T isn't linear. So you can't use matrices. You'll have to think more directly about what kernel and range mean. Start with the kernel. How can (x1,x2,x2*x3)=(0,0,0)?
You posted a completely different question to begin with. I wish I had quoted it. Then you deleted that question and substituted another. PLEASE DON'T DO THAT. Can you guess how confusing this can be?
You build a matrix representation by picking a basis [tex]\{v_1,\ldots,v_n\}[/tex] for V. Then a linear transformation [tex]L:V\rightarrow V[/tex] has a matrix representation [tex]L_{mn}[/tex] by decomposing [tex]L(v_m)[/tex] in terms of the basis according to
[tex]L(v_m) = \sum_n L_{mn} v_n.[/tex]
You should start with the definition of a contraction and apply that to an arbitrary basis vector.
(Dick, if I'm googling correctly, a contraction is a multiplication by a scalar a, with 0<a<1. charmmy should post the definition to verify this.)
Edit: I evidently didn't see the original version of the question...
its only possible if x1 =0; x2=0 and x3=0 right? so its the trivial solution?
The original question is back if you look quick. It might change at any moment.
I'ms so sorry about that. I didn't realize you've answered the question before I change it. Can I post both the questions under the same post then?
Don't change the question again, ok? Post a new thread for the other one. No, (x1,x2,x2*x3)=(0,0,0) doesn't just have the trivial solution. There are others.
Okay. sorry about the confusion
fzero: contraction does mean multiplication with a scalar between 0 and 1.
dick: hmm in that case, x3 would be a free variable? since x2 and x1 must be zero.
Yes. x3 doesn't matter. So the kernel subspace is (0,0,x3). Now what about the image?
the image would just be everything in R3 is that correct?
