Contrapositive of a (if p and q, then r) statement?
  • Thread starter Thread starter SithsNGiggles
    Contrapositive
The discussion revolves around proving the statement "If \vec{u} \neq \vec{0} and a\vec{u} = b\vec{u}, then a = b" through its contrapositive. Participants explore the formulation of the contrapositive, ultimately agreeing that a direct proof is simpler. The direct proof involves showing that if a\vec{u} = b\vec{u} with \vec{u} being non-zero, then the equality implies a = b by manipulating the equation (a - b)\vec{u} = 0. The conversation also touches on the concept of exclusive-or in the context of the proof, emphasizing the need to demonstrate that only one of the conditions can hold true at a time. The thread concludes with a consensus on the clarity of the proof's structure and the importance of understanding vector properties.
SithsNGiggles
I hope this is the right place to post this.
For my linear algebra homework, I have to prove that
"If \vec{u} \neq \vec{0} and a\vec{u} = b\vec{u}, then a = b."
I'm trying to prove the contrapositive, but I'm not sure how to alter the statement.
I think it's something like
"If a \neq b, then \vec{u}=\vec{0} or a\vec{u} \neq b\vec{u}."
But then I don't know where to begin, so I'm guessing a proof by contrapositive isn't the right method to use here. It seems to me that a direct proof might me simpler, but I guess I wanted to challenge myself. Any ideas? Thanks.
A direct proof would be simpler here. Basically what you're trying to prove is the cancellation law.
I'm sure you're in a field here, particularly a vector space. What do you know about the properties of a vector space? Think about axioms.
Well we know quite a few axioms, and we also know other properties as a result of earlier proofs.
My "direct proof" goes like this:
Let U be a vector space and \vec{u} \in U. Let a,b be arbitrary scalars.
Given that a\vec{u} = b\vec{u}, by substitution we have
\frac{1}{a} (a\vec{u}) = \frac{1}{a} (b\vec{u}).
By axiom 9 (an associative property),
(\frac{1}{a} \cdot a) \vec{u} = (\frac{1}{a} \cdot b) \vec{u}
(1) \vec{u} = \frac{b}{a} \vec{u}
So for equality to hold, we must have
1 = \frac{b}{a}, and from this it follows that
a = b. Q.E.D.
I wrote this up pretty quickly, so I agree that the direct proof is easier. Is there a way to work with the contrapositive, though? It doesn't look like it to me.
Wait what substitution? You multiplied by the left inverse of a, that's not a substitution. Also, your vector u doesn't automatically cancel out of thin air. The point is, you have to argue as to why u is going to cancel.
You have that u is non-zero and au = bu. You want to show that a = b.
Since u is a non-zero vector... hmm ;). Another hint is to abandon the fraction notation and use inverse notation.
My professor considers "multiplying both sides by the same thing" to be substitution. I think what he means by that is since, for example, for some vectors u and v, if u=v then au = av. Does that clear it up?
As for getting rid of the vector u, I just matched up the scalar coefficients. I don't how else to describe what it is I did there... I guess I'm saying I don't actually get rid of u. How is this normally shown in a proof knowing that u is non-zero?
Edit: I think I can answer my own question.
(1)\vec{u} = \frac{b}{a}\vec{u}
(1)\vec{u} + (-\frac{b}{a}\vec{u}) = \frac{b}{a}\vec{u} + (-\frac{b}{a}\vec{u})
(1)\vec{u} - \frac{b}{a}\vec{u} = \vec{0}
(1 - \frac{b}{a})\vec{u} = \vec{0}
Since u is non-zero, it follows that (1 - b/a) = 0, and then I solve to get a=b. Is this right?
If u is non-zero, then it has an inverse? What happens if you apply the inverse to what you're trying to show.
We haven't learned anything about inverse vectors, but I think I get what you're saying here. I figured another way which I added to my last comment.
Edit: Oops, I misinterpreted "inverse." I was thinking multiplicative for some reason...
Ah you haven't been taught about it. The problem with what you're doing is you're assuming a has an inverse. What if a=0? The whole thing goes down the drain.
Sorry, I was mistaken. We actually did learn about the inverse of a vector, namely the negative of a vector. I don't know... I knew of the additive inverse but it didn't quite register.
And it looks like I have to provide a proof for when either a or b are zero. Thanks for reminding me.
Why are you dividing by anything? You've got (a-b)u=0 where u is nonzero. Isn't that enough?
I believe the contrapositive here would be what you guessed it to be. As others have said, I think its easier to prove directly. For fun, let's prove the contrapositive, worded better for proving:
"For any vector u, in some vector space V, and any scalars a,b, in some field F, consider the equation au=bu, with truth of equality undetermined. If a \neq b, then either u=0 (so that au=bu), or au \neq bu."
Let's begin the proof. For the first case, suppose u\neq 0. Because by assumption a\neq b, we thus have a-b\neq 0. Therefore, we can conclude that
(a-b)u\neq 0
From this we can easily conclude by moving terms around that it must be that au\neq bu. (How?) Next, suppose instead (working on the second and final case) that u=0. To be clear, we want to draw from this that au=bu. Of course, that is obvious.
Note that, because this is a mathematical statement, the "or" component means we could have both parts of the conclusion of the statement, i.e. both that u=0 and au \neq bu. However, this cannot be. (Why?) So, I guess for this theorem (problem), it must be that we can only have one or the other condition, i.e. it is an "exclusive-or" conclusion, rather "inclusive-or."
This concludes the proof.
My bad if I did anything wrong. I'm a bit tired, but I feel like there's enough good info there to give reason for me to submit this reply, anyway
I looked over the proof last night and I realized that now (that I have (a - b)u = 0). Thanks!
And to 5hassay, I think I follow. Since it's an exclusive-or statement, would that mean I would only have to show one for the statement to hold?
SithsNGiggles said:
...And to 5hassay, I think I follow. Since it's an exclusive-or statement, would that mean I would only have to show one for the statement to hold?
If I understand correctly, since our conclusion is a "result 1 OR result 2" conclusion, and it appears we can only have one or the other, but not both, i.e. the "OR" as an "exclusive-or," then we must show both that result 1 can occur while result 2 does not occur, and, likewise, that result 2 can occur while result 1 does not occur
