Control System: Find the Transfer Function From Block Diagram
jaus tail
Block diagram of a control system with two summing junctions, blocks G1, G2, H1 and H2, input signals Ra and Rb, output signals CA and CB, followed by four multiple-choice transfer function options (A) to (D).
To find Ca / Rb we take Ra = 0 --- is this right?
I used mason's formula
P1 = -G2 G1 H1
Loop = G1, G2, -H1, -H2
Using Mason's Gain we get:
Delta1 = 1
Delta = 1 - G1G2H1H2
Using Mason's Gain
TF = -G1G2H1 Divided by ( 1 - G1G2H1H2)
But substituting the values I don't get the answer that matches any options.
Substituting I get:
Handwritten notebook working on a control system transfer function: path and loop gain terms with (s/(s+1)), (50s+1), 20/s, Delta = 1 - {loop gains}, leading to a final expression (s^2+s - 20s(50s+1)(10s+1)) over s^2+s.
This gives answer in cube as second term of numerator will go in cube for s. None of options have s cube.Second Question:
Block diagram of two cascaded feedback loops with input R(s) and output C(s); left loop has gain 10 and feedback 1, right loop has gain 5 and feedback 0.5, with answer choices A 5, B 10, C 15, D 50 below.
I think the options are wrong.
For left TF we get C(s)/R(s) = 10/11
For Right we get C(s)/R(s) = 5/3.5
Multiplying them doesn't give the answer
  • Block diagram of a control system with two summing junctions, blocks G1, G2, H1 and H2, input signals Ra and Rb, output signals CA and CB, followed by four multiple-choice transfer function options (A) to (D).
  • Block diagram of two cascaded feedback loops with input R(s) and output C(s); left loop has gain 10 and feedback 1, right loop has gain 5 and feedback 0.5, with answer choices A 5, B 10, C 15, D 50 below.
  • Handwritten working on lined paper showing transfer function derivations using Mason's gain formula, with terms such as G1, G2, H1, H2 and s-domain expressions.
  • Handwritten notebook working on a control system transfer function: path and loop gain terms with (s/(s+1)), (50s+1), 20/s, Delta = 1 - {loop gains}, leading to a final expression (s^2+s - 20s(50s+1)(10s+1)) over s^2+s.
It's been awhile since I've done these, but I got the same result as you, for the second one: C/R = 100/77. I haven't worked through the first one, yet.
yes
I got the same thing as you for the second problem.
In problem number one you can dive both the top and bottom side by s...
Not sure if that helps.
I'm getting: Ca/Rb = -G2 H1 G1 divided by (1 + ( -G2 H1 G1 H2 ) )
And that's not reducing to any of the options.
Sounds like the problem might be "hosed":eek:
Could be. Even I think the question has some typo.
