Control Volumes - Fluid Mechanics
5 replies · 2K views · last reply
sierra52
After doing extensive research, I am still confused about Control Volumes. Say that there is water flowing into a cup at a steady rate, and I am required to illustrate the momentum and mass flows, as well as the forces, how would I approach this? I have seen examples of Control Volumes but they do not reflect simple vertical flow and do not contain much information.
Thanks.
I am honestly not sure what you are asking here. What do you mean by "illustrate the momentum and mass flows"?
So depicting (via an illustration of the control volume) the mass flow and momentum of the fluid as it enters and leaves the control volume, noting that the flow is steady and vertical. I'm not sure at all how I sketch this. I hope this clarifies things. Thanks.
A control volume represents a basically imaginary region containing volume and as it relates to mass flow, the entering and exiting mass flow from a control volume must always be equal regardless of the shape of the control volume size or configuration between the fluid entry and exit end points.
(Note Edited to remove earlier erroneous statement related to momentum and inlet vs. outlet areas deleted.)
I am a bad engineer but let's give it a try :P
This question is not very clear, please provide some more information, is the cup stationary or moving, what is the hose dia, what is the velocity of water? Assuming the simplest case, the flow is steady,
you have first imagine a boundary across your cup, let for example the cup is resting on a flat surface and water is entering the cup vertically,
Hand-drawn diagram of a water stream of diameter x falling vertically into a cup of diameter y and height H, with a dashed control surface around the cup, beside an x, y, z coordinate system.
the total amount of forces acting in y directing would be:
Handwritten-style equation: sum of F_y = F_s + F_b = d/dt integral over C.V of V_y rho d-volume + integral over C.S of V_y rho V_n dA.
as the flow is steady C.V term would cancel out,
Fs = surface forces.
Fb = body forces.
from the assumption that the cup is at rest, Fs= Ry ;reaction.
Fb= weight of the cup plus weight of the water.
Handwritten-style typed derivation of a momentum balance for a control volume: sum of Fy = Ry - Wtotal equals minus the integral over the control surface of Vy rho Vy dA, reducing to Ry - Wtotal = -Vy mdot, then Vy = -mdot/(rho A), giving mdot squared over rho A.
Typed text with the equation m_entering = m_leaving + m_increase in mass of the system, followed by explanatory notes on calculating mass flow rate from volume flow rate and density.
You don't need a control volume (a conceptual thing) if you already have a cup a real thing).
In either case you can then proceed with normal physics, starting with mass/volume conservation.
