Baluncore
2025 Award
- 17,048
- 10,591
Here is a proof of concept. LTspice .asc attached as floatearth.asc.txt, remove .txt to run it.
DAC produces Vdac, perched on 50 volts of AC noise.
Pre-regulator makes Vpr ≈ 12 volt rail. Select a cheaper MOSFET, adjust zener voltage.
No model here for a 5 volt regulator following Vpr, here it is V7805. Called Vcc = 5V.
Supply rails do not need to be precise.
I have no model for the AD629 chip. Replace B_AD629 with a model.
Select two op-amps for Rail to Rail input and 15V supply.
