Convergence of a Recursive Sequence
The problem involves analyzing the convergence of a recursive sequence defined by Newton's Method, specifically the sequence given by x0 = 1 and xn+1 = xn - (tan(xn) - 1) / sec²(xn). Participants are tasked with determining whether this sequence converges or diverges.
  • Participants express uncertainty about how to begin the analysis and suggest using trigonometric identities. Some question the implications of the limit of the sequence as n approaches infinity and whether it approaches a specific limit L.
There is ongoing exploration of the sequence's behavior, with participants discussing the potential issues with the initial function definition and the implications of evaluating the sequence's terms. Some guidance has been offered regarding the evaluation of initial terms and the nature of convergence in relation to Newton's Method.
Participants note that the original function may have undefined points, and there is discussion about the nature of convergence in relation to the roots of the function being analyzed. There is also mention of the need for a formal proof of convergence, which may be required by the instructor.
zachfoltz
The following sequence comes from the recursion formula for Newton's Method.
x0= 1 , xn+1=xn-(tanxn-1)/sec2xn
Show if the sequence converges or diverge.
I don't really know where to start on this problem, I have tried to use some trig identities to no avail, but I don't know what else to do. Any help is appreciated, thanks!
What's the question?
oh sorry your supposed to show if it converges or not.
If the x_n converges to a limit L what happens to x_n+1 if n->inf?
I'm not sure, does it also approach L?
What is stopping you from computing a few of the initial x_n values, say for n = 1, 2, 3,... ? This might offer some insight.
One possible problem I can see is that your initial definition
[tex]f(x) = x - \frac{\tan(x)-1}{\sec^2(x)}[/tex]
is meaningless at ##x = \pi/2, 3\pi/2, \ldots## where both the numerator and the denominator are infinite, but the algebraically equivalent form
[tex]f_1(x) = x - \sin(x) \cos(x) + \cos^2(x)[/tex]
has no problems at any values of x. In other words, while your original f(x) is not defined at some x-values, we have ##f(x) = f_1(x)## at ##x \neq \pi/2, 3\pi/2, \ldots## and
[tex]\lim_{x \to p} f(x) = \lim_{x \to p} f_1(x) = f_1(p)[/tex]
holds for ##p = \pi/2, 3\pi/2, \ldots ##. In other words, f(x) has "removable" discontinuities, and can thus be replace by f_1(x) in the optimization algorithm. Is that the source of your problems?
Also, how could I prove that x_n converges to a limit L? Thanks for responding, I really want to get this problem, I just can't seem to get it on my own.
Ray Vickson said:
What are you attempting to do? What is stopping you from computing a few of the initial x_n values, say for n = 1, 2, 3,... .
I need to find what it converges to, so I believe that entails taking the lim as x -> ∞ but the lim of any trig function as it goes to infinity is undefined. Is that what I'm supposed to do?
No, that is not what you were asked about. You were asked to look at the sequence ##x_0 = 1, \: x_{n+1} = f(x_n)## for a given function f(x). You were asked if the sequence ##x_0, x_1, x_2, \ldots## is convergent.
So when I try to evaluate x1 I get x1=x0+1=x0-sin(x0)cos(x0)+cos2(x0)=(1)-sin(1)cos(1)+cos2(1). How can you evaluate this?
Use a calculator, or a computer package. You can even use an on-line facility such as Wolfram Alpha.
Ok, I used a calculator to continue to find the next number in the sequence about 4 or 5 inputs and I start to get .7853981634... every time. This should then be the number the sequence converges to, the only problem is that the initial equation was of the form of Newton's method, which is used to find x intercepts (roots/zeros). Therefore this sequence HAS to converge to zero, but I should be able to prove this.
Sorry, that is the answer, much thanks for the help!
NO, that is not the case. Newton's method seeks a solution of an equation g(x) = 0; it is g that needs to go to zero, NOT x! For example, if you want to compute √2 you can use Newton's method on the function g(x) = x^2 - 2. You will find that the x_n converge to 1.414213562... , and that g(x_n) → 0, and this is exactly what you need.
As for your problem, I just suggested you do computations in order to get a "feel" for what is happening. Whether or not that is an acceptable solution to your problem is something your instructor will decide. Perhaps he/she wants an actual proof of convergence, in which case the numbers themselves would not be enough.
