Convergence or Divergence? Tips for Solving Tricky Series Problems
  • Thread starter Thread starter weesiang_loke
The discussion revolves around the convergence or divergence of the series defined by the expression \(\sum_{n=1}^{\infty} (\sqrt[n]{n} - \cos(\frac{1}{n}))\). Participants explore various tests and approaches to analyze the series behavior.
  • Mixed
  • Participants discuss the application of the ratio test, root test, and comparison test, noting difficulties in reaching a conclusion. There are questions about the limits of the terms involved and their implications for convergence tests.
Several participants have offered insights into the potential applicability of the integral test and Cauchy's condensation test, while others express skepticism about the feasibility of these methods. There is an ongoing exploration of the series' behavior, with some participants suggesting that the terms may not be monotonically decreasing, which is a requirement for certain tests.
Some participants mention constraints related to their current understanding of calculus and the complexity of integrating the terms involved. There is also a correction regarding the original problem statement, which impacts the analysis being conducted.
weesiang_loke
inf
[tex]\sum[/tex] ( [tex]\sqrt[n]{n}[/tex] - cos ([tex]\frac{1}{n}[/tex] ) *** edited
n=1
the series converges or diverges?
ratio test, dirichlet's test, comparison test, etc
i tried a lot of method but still cannot get the answer...
from what i know, limit n to inf of n^(1/n) is 1 but limit n to inf of cos (1/n) is also one. so the divergence test cannot applied here.
besides, i tried the root test and ratio test but still cannot get the answer?
any help or hint would be appreciated... thanks
What is
[tex]\lim_{n\rightarrow +\infty}{\sqrt[n](n)+\cos(1/n)}[/tex]??
not limit but summation, a series
even if you take limit that way the answer will be zero. so it is not conclusive by divergence test..
The limit of n^{1/n} + cos(1/n) is NOT zero
limit n to inf n^(1/n) is one, right?
and limit n to inf cos(1/n) = cos (0) = 1.
so the sum of two limit is zero. pls tell me what i did wrong.. thanks
1+1 = 2, not 0.
sorry i copied the wrong question. it should be minus instead of plus
What about the integral test? I believe that may be conclusive...
Or the Cauchy condensation test?
for integral test... we need to at least to integrate (x^(1/x) - cos (1/x)). but i can't find a way to integrate x^(1/x) or cos (1/x)...
(may be my current understanding of calculus is not sufficient for the integration)
and i am not sure how to apply the Cauchy condensation test...
can you pls show me how to begin...
thank you very much...
Hmm, you are correct in that the integral test would be rather messy to bad...
But I still believe that the Cauchy condensation test would work. It says that
[tex]\sum{u_n}~\text{converges iff}~\sum{2^nu_{2^n}}~\text{converges}[/tex]
So, your series converges iff
[tex]\sum{2^n(\sqrt[n]{2^n}-\cos(2^{-n}))}[/tex]
converges. I believe that this simplifies the integral a bit...
This question is far too difficult for your level. The integral test or Cauchy's condensation tests won't work here, its not even immediately clear if the terms are monotonically decreasing, which are requirements for those tests. There is no simple solution, but here's a sketch of the solution for other peoples benefit.
[tex]\sqrt[n]{n} = e^{ \frac{\log n}{n}} = 1 + \frac{ \log n}{n} + O\left( \frac{\log^2 n}{n^2} \right)[/tex]
and [tex]\cos \left( \frac{1}{n} \right) = 1 + O\left(\frac{1}{n^2}\right)[/tex]
so [tex]\sqrt[n]{n} - \cos \left( \frac{1}{n} \right) = \frac{\log n}{n} + O\left( \frac{\log^2 n}{n^2} \right)[/tex], and since [itex]\sum \frac{\log n}{n}[/itex] diverges (comparison with harmonic series, Cauchy Condensation test or integral test all work easily for that), the sum in question diverges as well.
But, Cauchy's condensation test DOES work here! It gives us that we need to check convergence of
[tex]\sum{2^{n+1}-2^n\cos(1/2^n)}[/tex]
Since [tex]2^n\cos(1/2^n)\leq 2^n[/tex], we have that
[tex]\sum{2^{n+1}-2^n}\leq \sum{2^{n+1}-2^n\cos(1/2^n)}[/tex]
and the left sum diverges, so the right sum does to...
I think i got it now.
Thanks for the help, micromass, Gib Z and JG89.
Both methods actually work.
God bless you all and have a nice day.
Cheers,
weesiang_loke
