Convert 2x2 Matrix to 1x1 Tensor
  • Level: Undergrad
  • Thread starter Thread starter Vitani1
    Matrix rank Tensor
13 replies · 3K views · last reply
Vitani1
TL;DR
Trying to figure out how to transform tensors appropriately.
If I have a matrix representing a 2nd order tensor (2 2) and I want to convert this matrix from M$$\textsuperscript{ab}$$ to $$M\textsubscript{b}\textsuperscript{a}$$ what do I do? I'm given the matrix elements for the 2x2 tensor. When applying the metric tensor to this matrix I understand symbolically how to get this 1st tank tensor but I don't understand how to write it out.
To write subscripts and superscripts use _ and ^. To get ##M^{ab}## use M^{ab}. To get ##M^a{}_b## do M^a{}_b (the empty {} produce a zero width blank which the subscript hangs off - missing it out gives ##M^a_b##).
Applying the metric tensor to a rank-2 tensor doesn't give you a rank-1 tensor - it gives you a (1,1) tensor, which is also a rank-2 tensor. If you are representing the components in a matrix, it's still a 4×4 matrix. If you know how to write the expression, do you understand the Einstein summation convention? If so, can you write out explicitly what the ##\mu\nu## component of the result is in terms of a sum of products of the components of ##M## and the metric?
@Vitani1 I'm confused about what you are trying to do. Are you trying to raise an index on the tensor ##M##? Or are you trying to compute its trace, which is a scalar?
Raising an index, which is what is implied by your saying you want to convert the matrix from ##M_{ab}## to ##M_a{}^b##, would look like this:
M_{ab} \ g^{bc} = M_a{}^c
Taking the trace, which is what is implied by your saying you want to convert the matrix to a 1 x 1 tensor, which is a scalar, would look like this:
M_{ab} \ g^{ab}
The first thing you stated is correct. Say I have a tensor Mab (superscripts) and I apply this metric tensor to this matrix to lower one of its indices - how would I multiply this result out?
So you have ##M^{ab} \ g_{bc} = M^a{}_c## [Edit: fixed] in the standard notation using the Einstein summation convention. Do you understand how that convention works?
I take this to mean I multiply this matrix by a scalar given by the metric tensor g?
PeterDonis said:
So you have
Shouldn't it be ##M^{a}{}_{c}##?
PeterDonis said:
So you have ##M^{ab} \ g_{bc} = M_{ac}## in the standard notation using the Einstein summation convention. Do you understand how that convention works?
It's ##M^{ab} g_{bc}={M^a}_c##, and whenever two indices are the same (where one must be an upper and the other necessarily a lower index) you sum over ##a## (in GR from 0 to 3).
The metric components ##g_{ab}## are used to convert an upper index (contravariant) to a lower index (covariant).
Solved. Thanks! By the way there is a nice problem about this in A First Course In General Relativity by Schutz (Chapter 3, problem 24)
