Convert a Quadrangle to a Triangle
  • Thread starter Thread starter luonganh89
    Convert Triangle
3 replies · 2K views
luonganh89
Hi all !
I got stuck in establising an method to Convert a Quadrangle mesh to a Triangle mesh (CFD).
I have a mesh file (.dat) which have information:
Number of Element - Node 1 - Node 2 - Node 3 - Node 4
1 1 2 3 4
2 3 4 5 6
Have anyone done like me. Can share me some information thank you so much
luong anh
pfiev
You need to be more specific.
What exactly is the problem?
What is the method that you established and where are you stuck?
The obvious thing to do is turn each quadrilateral into two triangles by drawing a diagonal. But if the quadrilaterals are curved (i.e. a 3D surface) the results may look different depending on which diagonal you choose.
If that is a problem, maybe you need to find the "center" of the quadrilateral (i.e. the average of the 4 corner points) and join that to the corners to make 4 triangles.
As gsal says it really depends what the triangle mesh will be used for.
:D of course , I've just wanted to remesh my model, and i write a short code to remesh it and open it by using tecplot , but now i come back home , tomorrow i will send my result to you but i got some trouble @@
