Convert British and SI Units Easily
12 replies · 4K views
ank_gl
hey can anyone give a calculator(like any html link) or something of that sort which can convert units, like from british system to SI units and vice versa. looking at the tables everytime is sooooo boring and i am fed up of it.for eg. changing lengths, pressure, weight etc. etc.:-p:-p
If you can find one, the ultimate conversion machine is a HP28c. You can create unit strings then as long as they are compatible hit the convert key and it gives you the conversion with the final units. The built in list of fundamental units is huge, it covered everything I have ever heard of, plus more.
CompuChip said:
Try this one
Just type, e.g. "70 degrees F to degrees C"
or "3*Pi to degrees"
of "feet to m"
It's perfect.
:smile::smile:hey its perfect:-p:-p
guess i ll hit the store today for this machine:-p:-p
For Unix/Linux users, there is an unobtrusive command line utility, units[/color]:
Code:
$ units 7lb kg
        * 3.1751466
        / 0.31494609
i.e. outputs converted amount and the multiplier of inverse conversion; or in interactive mode:
Code:
$ units
2438 units, 71 prefixes, 32 nonlinear units
You have: 15 knots
You want: mph
        * 17.261692
        / 0.057931749
You have: lbf
You want:
        Definition: lb force = 4.4482216 kg m / s^2
The definitions of known units are in /usr/share/misc/units.dat, and if said ~2500 were not enough, one could add ones own :)
Chusslove Illich (Часлав Илић)
FredGarvin said:
It kicks butt.
i didnt get it:confused::confused:
For most unit conversions I have to do, I will use either MathCAD or my TI-89. Both are capable of unit-aware calculations as well as user-defined units.
While the HP28c might be pretty good, I wouldn't say it's the "ultimate." It's important to note that the TI-89 is easy to find, and relatively inexpensive for its vast capabilities (units and unit conversions being one small part of it). The built-in units list of a TI-89 is quite large, and defining new units is as simple as defining a variable. Unit-aware calculations means it is also able to combine units in calculations for "unit simplification" (such as 0.5 kg * (1 m/s)^2 = 0.5 J).
You can also find a TI-89 emulator on the internet, which would be a simple way to give you these calculation capabilities on your computer. Do a search on Google or over at ticalc.org for more details.
thanks mech engineer for that emulator, it ll surely help me understand that calcy
