Converting cartesian surface integral to polar
To convert the Cartesian surface integral of x² + y² over a circular region to polar coordinates, the integrand can be replaced with r². However, an extra factor of r is necessary in the differential area element, resulting in the expression ∫₀²π ∫₀ᵣ r³ dr dθ. This extra r accounts for the area element in polar coordinates, which is proportional to the radius. The conversion also requires adjusting the limits of integration to reflect the polar coordinate system. The final integral yields the same result as the Cartesian calculation, confirming the transformation's validity.
jbar18
If I have an integral:
\int\int_{R} x^{2} + y^{2} dy dx
Where the region R is the area enclosed by a circle centered on the origin of any given radius, is it possible to just convert x^2 + y^2 to r^2 and integrate from 0 to r over dr and 0 to 2 pi over d\theta?
So it would become:
\int^{2\pi}_{0}\int^{r}_{0} r^{2} dr d\theta
I have seen this done before, but for some reason there was an extra r, with the dr. I'm not sure if this was a mistake or not, but I can't see any reason for it to be there. Unfortunately, when I saw it before the radius of the circular region was 1, and so I could not check through another method, since both gave the same answer. I was also unsure if the r in the boundary should be the same as the r in the integrand. Could somebody explain if there is supposed to be an extra r there, or if anything is wrong with the transformation? So far as I can tell, it is as simple as just replacing x with rcos(\theta) and y with rsin(\theta), but the way I saw it done before suggests otherwise.
Thank you for any help.
You are perfectly correct in replacing x by rcos(θ) and y by rsin(θ) in the integrand. The hitch comes in what should be used for the differential element of area. In cartesian coordinates, that"s pretty obviously dxdy. But if you draw a picture of it in a polar system, you will note that the element of area is bit pie shaped, and that for a given dθ, its area is proportional to its distance from the origin. Hence, the polar differential of area is rdrdθ. That's where the extra r comes from.
Also note, that if x and y correspond to some measure having units of say, meters, then the cartesian integral has units of meters squared. Since dθ is unitless, there must be an extra unit of meters coming from somewhere in order for the polar integral to be consistent!
The expression you want is
\int_0^{2\pi}\int_0^R r^3 \, \mathrm{d}r \, \mathrm{d}\theta = \frac{\pi R^4}{2}
where R is the radius of the circle, a constant, and the r in r^2=x^2+y^2 is a variable. This gives the same result as the harder-to-compute formulas in Cartesian coordinates, for example
\int_{-R}^R\int_{-\sqrt{R^2-x^2}}^{\sqrt{R^2-x^2}}(x^2+y^2)\, \mathrm{d}y \, \mathrm{d}x.
In general, to convert an integral from Cartesian to some other coordinate system we need to do three things:
(1) Compose the integrand with the coordinate transformation from "other" to Cartesian. In your example, that means replacing x^2+y^2 with r^2, since x=r \cos\theta and y=r \sin\theta, and
r^2\cos^2\theta+r^2\sin^2\theta = r^2(\cos^2\theta+sin^2\theta)=r^2.
(2) Multiply the integrand by the appropriate conversion factor (to account for the different ways that area is represented in the different coordinate systems, as obafgkmrns explained), namely the absolute value of the determinant of the Jacobian matrix of the coordinate transformation function from "other" to Cartesian. Think of the transformation as a function T from \mathbb{R}^2 to \mathbb{R}^2:
T( r,\theta ) = ( r\cos\theta,r\sin\theta ).
Its Jacobian is the matrix of partial derivatives whose ij entry is the parial derivative of the ith component of T with respect to the jth input variable. Thus, in this case
J=\begin{pmatrix}<br /> \frac{\partial (r\cos\theta)}{\partial r} &amp; \frac{\partial (r\cos\theta)}{\partial \theta}\\ \frac{\partial (r \sin\theta)}{\partial r} &amp; \frac{\partial (r \sin\theta)}{\partial \theta}<br /> \end{pmatrix}=\begin{pmatrix}<br /> \cos\theta &amp; -r\sin\theta\\ <br /> \sin\theta &amp; r\cos\theta<br /> \end{pmatrix},
and \left | \det(J) \right |=r.
(3) Express the limits of integration in terms of the "other" coordinate system.
The principle is exactly the same for \mathbb{R}^3 and higher dimensions. In one dimension, it corresponds to the method of substitution (=reverse chain rule) for a single-variable integral.
A footnote.
I hope someone with more expertise will correct me if I'm wrong, but it seems to me that the use, for multivariable integrals, of the absolute value in the "integration by substitution" formula is due to convention, rather than to any inherent distinction between single-variable and multivariable integrals.
When the integrand is a function of one variable, i.e. f:\mathbb{R}^1 \rightarrow \mathbb{R}^1, the convention is simply to substitute the old variable for the new in the limits. The sign of the derivative of the coordinate transformation function is necessary to correct for any change in orientation.
But when the integrand is a function of more than one variable, i.e. f:\mathbb{R}^n \rightarrow \mathbb{R}^1, with n\neq 1, then I guess the convention must be to quietly flip the limits so that the lower limit is always less than the upper limit without multiplying the integrand by -1. If the coordinate transformation changes the orientation, this will introduce an erroneous factor of -1. But in that case, Jacobian determinant will be negative, and taking its absolute value introduces another factor of -1, correcting the first.
For example,
\int_0^1\int_0^1(x^3+y)\,\mathrm{d}y \, \mathrm{d}x = \frac{3}{4}.
Let \phi(u,v)=(-u,v). Then the Jacobian is
\begin{pmatrix}<br /> -1 &amp; 0\\ <br /> 0 &amp; 1<br /> \end{pmatrix},
and its determinant -1.
\int_0^{-1}\int_0^1((-u)^3+v)(-1)\, \mathrm{d}v \, \mathrm{d}u = \frac{3}{4}
=\int_0^{-1}\int_0^1 f \circ \phi(u,v) \cdot \det(J) \, \mathrm{d}v \, \mathrm{d}u
=-\int_{-1}^0\int_0^1 f \circ \phi(u,v) \cdot \det(J) \, \mathrm{d}v \, \mathrm{d}u
=\int_{-1}^0\int_0^1 f \circ \phi(u,v) \cdot (-\det(J)) \, \mathrm{d}v \, \mathrm{d}u
=\int_{-1}^0\int_0^1 f \circ \phi(u,v) \cdot\left | \det(J) \right | \, \mathrm{d}v \, \mathrm{d}u.
yeah you have to add in an extra r; rdθ defines an arc length, dr gives you the radius.
  • · Replies 29 ·
  • · Replies 19 ·
