Converting N/cm² to kg/cm² with correct unit factors
  • Level: Undergrad
  • Thread starter Thread starter kasnay
    Units
13 replies · 2K views
kasnay
Im trying to us 1.6*10^7 N/cm^2. this breaks to (kg*m/s^2)/cm^2. I need my units in terms of cm. So can I convert 1.6*10^7 kgm/s^2/cm^2 to
1.6*10^11 (kgm/s^2)/(m^2) then reduce to 1.6*10^11 kg/ms^2. The go back to cm and have 1.67*10^9kg/cms^2
  • Wow
First, it's pretty hard to read this when you don't use LaTeX. Please read the LaTeX Guide link below the Edit window to start using LaTeX. Thank you.
Second, I don't understand what you mean when you say you want to convert from ##cm^2## to ##cm##. Those are not compatible...
Also, most of your equation uses ##mks## units, and it's generally bad to mix ##cm## into ##mks## equations...
Better yet, please explain why you feel you need to make that conversion and we might be able to help you with that.
Yes, ##1.6 \ 10^7 \mathrm{\ N/cm^2}=1.6 \ 10^9 \mathrm{ \ kg/(cm \ s^2)}##
Also note that units must be typeset in Roman (non-italic) symbols!
Interesting! I just used the default LaTeX font. How would I switch fonts in LaTeX? I'm off to the LaTeX Guide for some research...
Okay, I see how to switch to Roman, but don't see yet how to switch back to the default font...
##\mathrm cm^2##
You have to use \mathrm{m} to typeset the symbol for the unit meter within a formula: ##\mathrm{m}##. To get ##A=1 \mathrm{cm}^2## just type a=1 \mathrm{cm}^2.
anorlunda said:
I know there's no good alternative, but Latex sucks IMO.
What I find annoying is that sometimes the characters don't line up properly. Look at ##A=1 \mathrm{cm}^2##. The bottom of the c is not properly lined up with the bottom of the m. Sometimes I find it convenient to use the default font instead of \mathrm{} as in ##A=1~##cm##^2##. In LaTeX #A=1~#cm#^2# where all # signs are doubled. That lines up the characters nicely.
But it's ok to use kilograms instead of grams?
You can use any units you wish as long as you are clear about what they are. An exception might be when you enter quantities as answers to online homework problems. There you have to enter the numbers in the units the algorithm expects from you.
I also don't see any problem to use cm within the SI. Why should this be a problem?
