Converting specific gravity to pressure in hydrostatic formula
  • Thread starter Thread starter TyErd
    Height Pressure
11 replies · 5K views · last reply
TyErd
question is in the diagram.
basically I am not sure how to use the specific gravity and convert it into pressure.
P=p(rho)gh
Hi TyErd! :smile:
(have a rho: ρ :wink:)
Use the specific gravity to find ρ, the density …
ρ-of-oil = ρ-of-water times specific-gravity-of-oil :wink:
(so specific gravity of water = 1)
ohhh! so the density of any liquid is density of water x specific gravity of the liquid?
in knowing that my working out is where density of water is 1000...: 80 + 1000(0.3)(9.81) - 1000(13.6)(9.81)(h) - 1000(0.72)(9.81)(0.75) = P_atmospheric. now what, i have two unknowns or do i assume P_atm is 101.325?
even if i do use 101.325 the answer is still wrong... i don't know why.
Hi TyErd! :smile:
(just got up :zzz: …)
Yup! :biggrin:
ah, the question says the gage pressure (or gauge pressure) is 80 KPa …
gauge pressure is defined as actual pressure minus atmospheric pressure …
so you can ignore the atmospheric pressure! :wink:​
oh yeah so then what does all of that equal? it should equal the pressure at the top of the oil column so would that just be the 0 because we can assume the mass of air negligible?
TyErd said:
oh yeah so then what does all of that equal? it should equal the pressure at the top of the oil column so would that just be the 0 …
yes :smile:
the sum of the mgh's has to equal the difference between the outside air and the measurer (80 KPa) …
you can think of them as being an initial and final pressure, much like initial and final energy in a "solids" equation :wink:
… because we can assume the mass of air negligible?
no, the mass of air is very heavy, it's because the 80 KPa is given as the difference from that :wink:
okay so i did this: 80 + 1000(0.3)(9.81) - 1000(13.6)(9.81)(h) - 1000(0.72)(9.81)(0.75) =0, h=-0.017047 which is incorrect. where have i gone wrong?
TyErd said:
even then its incorrect. the answer is h=0.582m
I do get 0.582 :confused:
Please show your full calculations.
