Applying Convolution to a PDE with a Fourier Transform
The discussion focuses on solving the PDE \( u_{xx} = u_t + u_x \) using Fourier transforms. The initial transformation leads to the expression \( F\{u\} = F\{f(\omega)\} \exp(-(\omega^2 + i\omega)t) \). Participants clarify the correct form of the Fourier transform and the importance of normalization, while also discussing the convolution theorem. The conversation emphasizes the need to apply the inverse Fourier transform to both \( F\{f(\omega)\} \) and the exponential term to find the solution. Ultimately, the Green's function for the heat equation is derived, incorporating a change of variables to address the convection term.
member 428835
$$u_{xx}=u_t+u_x$$ subject to ##u(x,0)=f(x)## and ##u## and ##u_x## tend to 0 as ##x\to\pm\infty##.
Fourier Transform
Taking the Fourier transform of the PDE yields
(\omega^2-i\omega) F\{u\}= \partial_t F\{u\}\implies\\
F\{u\} = \exp(t/4)F\{f(\omega)\}\exp((\omega-i/2)^2t)\implies\\
u = \exp(t/4)\int_{-\infty}^\infty f(\omega)\exp((\omega-i/2)^2t)\exp(i\omega x) \, d\omega
$$ From here I don't know how to apply convolution. Can anyone help?
What is the function that has ##\exp((\omega-i/2)^2t)## as its Fourier transform?
Edit: Also, ##i^2 = -1## ... You should have ##\exp(-(\omega+i/2)^2t)##.
Thanks for the correction. And a Gaussian transforms another Gaussian I believe, which is why I casted it in that form. I know $$F\left( \sqrt{\frac{\pi}{\alpha}}\exp(-x^2/4\alpha)\right) = \exp(-\alpha\omega^2).$$ Then the inverse transform of ##\exp(-(\omega-i/2)^2t)## where ##\alpha = 1/t## should be ##\sqrt{\pi t}\exp(-t(x-i/2)^2/4)##. What do you think?
I think you are guessing rather than performing the proper contour integral in the complex plane.
Yea I was looking at a formula that looked applicable. To work it out we'd have $$\int_{-\infty}^\infty \exp(-(\omega-i/2)^2t)\exp(i\omega x)\,d\omega = \int_{-\infty}^\infty \exp(-(\omega-i/2)^2t+i\omega x)\,d\omega\\
=\sqrt{\frac{\pi}{t}}\exp\left( -\frac{x(2t+x)}{4t} \right)$$
How does that look for the inverse Fourier transform?
... and multiplying this by the exponent you already extracted gives you? (In fact, it is preferable not to complete the square until you have the Fourier integral...)
You might also want to double check the normalisation of your Fourier transform and that of the table you are getting your transforms from.
Gotcha, so this gives us $$\sqrt{\frac{\pi}{t}}\exp\left( \frac{(t-x)^2}{4t} \right).$$ But how do I apply this to use convolution?
You should still double check the normalisation. And there is now a missing sign in the exponent.
Then use that the Fourier transform of a convolution is the product of the Fourier transforms.
Shoot, we should have $$\sqrt{\frac{\pi}{t}}\exp\left( -\frac{(t+x)^2}{4t} \right)\exp(-t/2).$$ Can you elaborate on what you mean by "use that the FOurier transform of a convolution is the product of the Fourier transforms?
Your conclusion in post 8 was closer. Note that the sign of the exponent with the t also changes due to your original sign error. Again, the best thing is to wait with completing the square until you have the inverse FT integral.
If you are not familiar with the convolution theorem, I suggest reading up on it. It should be explained in any introductory textbook on Fourier transforms. Or you can start on Wikipedia https://en.m.wikipedia.org/wiki/Convolution_theorem
Note the issues with normalisation.
Shoot, yea I made an algebraic error. For completeness the equation after transforming the PDE should read $$
-(\omega^2+i\omega) F\{u\}= \partial_t F\{u\}\implies\\
F\{u\} = F\{f(\omega)\}\exp(-(\omega^2+i\omega)t)\implies\\
u = \int_{-\infty}^\infty F\{f(\omega)\}\exp(-(\omega^2+i\omega)t)\exp(i\omega x) \, d\omega\\
= \exp\left(- \frac{(x-t)^2}{4t} \right)\int_{-\infty}^\infty F\{f(\omega)\}\exp\left( -t\left(i\frac{x-t}{2t}-\omega\right)^2\right) \, d\omega$$ Proceeding (if this is correct), convolution seems to imply I should take the inverse Fourier transform of ##F\{f(\omega)\}## and ##\exp\left( -t\left(i\frac{x-t}{2t}-\omega\right)^2\right)## and multiply these together?
Up to a factor of ##1/2\pi## depending on normalisation of the Fourier transform.
Note that the Green's function of the heat equation is
\frac{1}{\sqrt{4\pi t}} e^{-\frac{x^2}{4t}}.
The difference in your case is the appearance of the convection term. You can get rid of it using an appropriate change of variables ##\tau = t##, ##\xi = x-t##. This is also the procedure you would obtain using the method of characteristics. If you do this, you will get the standard heat equation ##u_\tau = u_{\xi\xi}##. Reinserting your original coordinates into the resulting Green's function immediately gives
G(x,t) = \frac{1}{\sqrt{4\pi t}} e^{-\frac{(x-t)^2}{4t}}.
