Coordinate singularity in Schwarzschild solution
6 replies · 3K views
Confused Physicist
Hi! I have the following problem I don't really know how to approach. Could someone give me a hand?
The line element of a black hole is given by: [tex]ds^2=\Bigg(1-\frac{2m}{r}\Bigg)d\tau ^2+\Bigg(1-\frac{2m}{r}\Bigg)^{-1} dr^2+r^2\Big(d\theta ^2+\sin^2(\theta)d\phi ^2\Big)[/tex]
It has an apparent singularity at ##r=0##. By making ##\tau## an angular coordinate, show that this singularity is a coordinate singularity (not physical) and find the period of ##\tau## that makes it possible. (consider expanding the metric functions about ##r=2m##).
Thanks for the help!
Note that this is not the usual Schwarzschild metric; there is no minus sign in front of the first term on the RHS. (If there were, the question would not make sense because ##\tau## would not be able to be treatd as an angular coordinate.)
Are you sure the problem statement says ##r = 0## and not ##r = 2m##?
Thanks PeterDonis, I will post my future questions in the homework forum. I've been trying to squeeze my head around it, but I haven't posted my attempt because I literally don't have a decent one.
Yes, the problem says ##r=0##, but you're right. I believe it's a mistake and it should say ##r=2m##.
What does it mean to treat ##\tau## as an angular coordinate? Is it a specific change of variable?
It means it only covers the range ##0## to ##2 \pi## instead of ##- \infty## to ##+ \infty##.
