Copper plating a non metallic material
  • Thread starter Thread starter wolram
    Copper Material
This discussion focuses on the process of copper plating non-metallic materials using a silver paint base. The user seeks to estimate the time required to deposit a 25-thou thick layer of copper, utilizing a variable voltage and amperage power supply set at 12 volts. Key principles include Faraday's Law of Electrolysis for calculating charge in coulombs and the importance of establishing an initial conductive layer for effective electroplating. Techniques such as corona treatment for surface ionization and the use of cathodes positioned behind non-conductive surfaces are also highlighted.
  • Understanding of Faraday's Law of Electrolysis
  • Knowledge of electroplating techniques
  • Familiarity with variable voltage and amperage power supplies
  • Experience with surface preparation methods such as corona treatment
  • Research the application of Faraday's Law in electroplating calculations
  • Learn about the process of corona treatment for surface preparation
  • Explore methods for establishing a conductive layer on non-metallic substrates
  • Investigate the effects of current density and cathode spacing on plating time
This discussion is beneficial for hobbyists and professionals involved in electroplating, materials science, and surface engineering, particularly those working with non-metallic substrates.
wolram
Dearly Missed
I want to copper plate a non metallic material I will be using genuine silver paint to coat the material, my problem is how to estimate the time it takes to deposit a layer 25 thou thick.
I have a variable voltage, amperage power supply, i guess it has some thing to do with varying the amperage
if i set the voltage at 12 volts.
The tank i have is 2ft by 1ft by1ft
Any ideas please.
Chemistry news on Phys.org
What area? You're going to be plating out some volume of metal; current times time for copper is what?
According to Faraday's Law of Electrolysis the charge in coulombs needed to deposit m grams of material with a valence number n and atomic mass M is
Q = 96520⋅ n⋅m/M (coulombs)
To obtain a certain thickness you need the area of the plated surface to get the mass plated. By monitoring the current flow you should be able to obtain the time it takes.
I haven't worked with electroplating before; how do you start the plating of a non-conducting object? It seems more straightforward after you have the initial conducting layer plated on so you can make electrical contact, but I'm not understanding how the first layer adheres to the non-conducting object. Thanks. :smile:
In extrusion coating, i.e. polymer coated paper, the substrate is ionized by corona treatment. This gives the coating a charged surface for the polymer in which to adhere. I imagine a similar process is used for metallized coating on plastic. Mylar is commonly metallized.
Electroplating is accomplished by placing the cathode behind the non conductive surface. Electroplate time depends on the spacing between the cathode and deposition surface and current density.
