Swamp Thing
- 1,077
- 848
From another recent thread I learned that you see a Coriolis force if an object in a rotating reference frame moves along a tangent at some velocity v. (I was already familiar with the case where the velocity is radial).
I still find it a little counter-intuitive that the force has the same magnitude irrespective of whether the velocity is directed radially or tangentially. When you move radially towards the center of rotation, you are dashing headlong from a "fast lane" into a "slow lane", so you will soon see a growing mismatch between your own tangential velocity and the local velocity of the surface that you are running over. Fair enough.
But when you move along the tangent, you are following approximately the same direction that the local surface is following anyway, only faster. So you are merely sidling or drifting, in an incidental manner, from a "fast lane" into a "superfast lane" where the local surface velocity is trying to leave you behind.
So intuitively, the Coriolis force in the second example should be an order smaller than in the first. Now obviously, my intuition is wrong -- but is there a simple, correct intuitive picture that will make it at once clear why the two cases produce exactly the same Coriolis force?
