Coriolis movie of draining pool?
  • Thread starter Thread starter cdorman2
    Coriolis Movie
The discussion centers on the Coriolis effect and its demonstration in draining water, specifically in larger pools rather than smaller fixtures like bathtubs. A user seeks videos of experiments similar to a 1950s demonstration involving a large indoor pool that effectively showcased the effect after water had settled for a week. Historical experiments by physicist Ottokar Tumlirz are referenced, highlighting a carefully controlled setup that allowed for the observation of water rotation after draining. The results indicated that the initial rotation from Earth's movement could be amplified, creating a noticeable vortex. The conversation emphasizes the need for accessible visual resources to aid in understanding this phenomenon in educational settings.
cdorman2
So we all know the Coriolis effect isn't demonstrated in a bathtub or toilet. Are there any videos online of the size of pool needed to demonstrate it? I saw one in grad school--black and white from the '50s--an indoor, above-ground pool with a drain in the center, allowed to settle for a week before the drain was removed. Haven't found anything like it make it to the Web, despite searching off and on for a year. Anybody else find something similar? Would help my class discussion a little...
Thanks,
Charles
"In 1908, the Austrian physicist Ottokar Tumlirz described careful and effective experiments which demonstrated the effect of the rotation of the Earth on the outflow of water through a central aperture. The subject was later popularized in a famous article in the journal Nature, which described an experiment in which all other forces to the system were removed by filling a 6 ft (1.8 m) tank with 300 US gal (1,100 L) of water and allowing it to settle for 24 hours (to allow any movement due to filling the tank to die away), in a room where the temperature had stabilized. The drain plug was then very slowly removed, and tiny pieces of floating wood were used to observe rotation. During the first 12 to 15 minutes, no rotation was observed. Then, a vortex appeared and consistently began to rotate in a counter-clockwise direction (the experiment was performed in Boston, Massachusetts, in the Northern Hemisphere). This was repeated and the results averaged to make sure the effect was real. The report noted that the vortex rotated, "about 30,000 times faster than the effective rotation of the Earth in 42° North (the experiment's location)". This shows that the small initial rotation due to the Earth is amplified by gravitational draining and conservation of angular momentum to become a rapid vortex and may be observed under carefully controlled laboratory conditions."
https://en.wikipedia.org/wiki/Coriolis_effect
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
