Could a blimp shrink into a plane?
The discussion centers on the conceptual design of a hybrid airship that can transition into a plane by retracting its skin and utilizing buoyancy and lift. Key challenges identified include the storage of extra materials, the need for rigid and aerodynamic skin, and the machinery required for expansion and contraction. Participants emphasize the importance of understanding the lift versus buoyancy trade-off during the transition phase and question the practical advantages of such a hybrid design compared to existing aircraft. The conversation highlights the complexities involved in creating a functional and efficient hybrid airship.
  • Understanding of hybrid airship mechanics
  • Knowledge of aerodynamic principles
  • Familiarity with buoyancy and lift concepts
  • Awareness of material science related to flexible and rigid structures
  • Research the mechanics of hybrid airships and their classifications
  • Explore aerodynamic design principles for efficient aircraft
  • Investigate material technologies for flexible and rigid aircraft skins
  • Study the lift versus buoyancy trade-off in aviation
Aerospace engineers, aviation designers, and anyone interested in innovative aircraft concepts and hybrid airship technology.
MUZE
I can imagine a frame within a blimp/hybrid airship so when the hydrogen inside the blimp is recaptured the skin retracts to form a wing. As the blimp travels faster it shrinks, the buoyancy giving way to the lift from its wing shape to a point in which it is no longer a blimp, but a plane.
What problems may arise from this conceptual aircraft?
Scale aside this would be the rough general shapes of it on take-off and during flight.
How would one
class this type of aircraft?
  • Revision 8.docx
    Revision 8.docx
Likes Lnewqban
The general term is hybrid airship. Since few, if any, became production models I would take the list of different hybrids in the article 'with several grains of salt'.
The term "hybrid airship" has also been used to describe an airship comprising a mix of rigid, semi-rigid, and non-rigid construction.
Likes MUZE
A few problems I see off the top of my noggin:
  1. Where would all the extra material be stored? It would take up premium payload space.
  2. How would you turn a material - that is flexible enough to be compacted into the nooks and crannies of a plane - into a skin tight and rigid enough to not create deleterious drag from flapping around in the winds?
  3. How much extra machinery would be required to expand and contract the structure? How much hydrogen tank volume? How many heavy pumps?
  4. How much structure would the plane itself require in its surfaces to perform double duty supporting alternately aerodynamic functionality and balloon support?
  5. How big does such a dirigible have to be to be buoyant? How big would a plane have to be to support everything needed for the hybrid? Or, look at it the other way: how small could you make such a plane? If you don't get sufficient reduction in size, then you may not have much reason left to have an airplane form - it would still need dirigible-sized landing and takeoff areas.
Likes Lnewqban, Klystron and MUZE
It comes down to functionality:
What advantage is gained by having this hybrid? Specifically, what advantage - other than convenience/speed - would be had by having a plane form - to offset the inevitable trade-offs?
Tell us what problem you're trying to solve.
Likes Klystron
Maybe not as dramatic but enough to be efficient at faster speeds. Maybe a more tubular design for traveling higher and faster. It would just get thinner with less cross-section.
I think you're describing a rocket.
Seriously. In addition to all of the other problems, you will have to solve the lift vs. buoyancy trade off at every moment during the transition. I expect there is an in between configuration where you have a heavier than air craft with a wing shape that doesn't produce enough lift. It's a difficult problem, especially in a commercial market place that places extreme value on efficiency.
Some people listed some problems, but can you say what benefits you would see to this idea vs current aircraft?
  • · Replies 21 ·
