Coulombs law and electric fields
The discussion focuses on Coulomb's Law and electric fields, specifically addressing the calculation of forces between point charges. The participants utilize the formula F = k * q1 * q2 / r^2 to determine the distance between protons and the forces acting on a third charge placed between two others. They clarify the vector sum of forces acting on the third charge and discuss the behavior of electric field lines around negatively charged spheres arranged in an equilateral triangle. A Java applet is recommended for visualizing electric field lines and equipotential surfaces.
  • Coulomb's Law and its formula (F = k * q1 * q2 / r^2)
  • Understanding of electric charge (positive and negative)
  • Concept of electric field lines and their behavior
  • Vector addition of forces in physics
  • Study the application of Coulomb's Law in various charge configurations
  • Learn about electric field visualization tools, such as the Falstad Java applet
  • Explore Lami's theorem and its implications in electrostatics
  • Investigate the concept of equipotential surfaces in electric fields
Students of physics, educators teaching electrostatics, and anyone interested in understanding electric fields and forces between charges.
pinkyjoshi65
Hey, just wanted to check my method.
1)What is the distance between 2 protons experiencing a mutually repelling force of magnitude 4*10-11?
so for this, we have to use the formula for coulombs law--F=kq1q2/r^2
we know F and k. And q1=q2= 1.602*10-19. hence we can find r.
2)Two point charges, 4*10-5 C and -1.8*10-5 C are placed 24 cm apart. What is the force on a third small charge of -2.5*10-6 C, if it is placed on the line joining the other two midway between the originally given pair of charges.
For this what i did was:
Find Fq3q1. The force for this will be in the left direction.
then i found Fq3q2. Force for this will be in the right direction.
Then i found the sum of the forces, and that is the force on q3.
Note: q3 is in the middle of q1 and q2. distance between q3 and q1 is 0.12 m. the same is tru for the distance between q3 and q2.
Sounds right?
your Fq3q2 should be in your left direction, and what do you mean by sum of forces (vector sum or algebraic sum)?
how will Fq3q2 will in the left direction. q3 is in between q1 and q2.so Fq3q1 is in the left direction and Fq3q2 is in the right direction.
by sum of forces i mean the vector sum
Unlike charges attract, Like charges repel, so ... (you got it?)
ahh..k..got it..thnkz..one more question..three small, negatively charged spheres are located at the vertices of an equilateral triangle.The magnitudes of the charges are equal. Sketch the electical field in the region around this charge distribution, including the space inside the triangle.
ok..so all i know is that density of field lines will be more whr the field is greater..
ah.. too hard..
I'll try and come back to you as soon as I get something of it.
anyone?
Electric field lines will converge to these three negative charges from outside. They are indipendent of each other beacuse field lines repell each other. There will be no field lines in the space inside the triange because if you keep a positive charge any where inside the triangle it will be at rest due to Lami's theorem.
umm..still unclear on where to place the positive test charge. I know that charge flows from positive to negative...
help anyone..?
The applet (in the link) shows the electric field lines in the area around the equilateral triangle (you have to make a triangle yourself, though). When you place a test charge anywhere on the plane, the arrow shows the direction in which the test charge will move. (hope this helps)
10K
