Bandersnatch
- 3,266
Inertia is the resistance to acceleration. What you have been conceptualising as countering here - the spin of the Earth - is velocity. In common parlance the distinction can be blurry.
When viewed from a non-rotating reference frame - here it means the point of view of the Sun and the background stars - a point at the surface of the Earth at the equator has some linear velocity. If you want the drone to hover above that point as seen from the non-rotating reference frame, it has to have equal but opposite velocity, in addition to its hovering action.
Once you impart that velocity through the use of some force (like the drone's engines), and in the absence of other forces (like drag from the atmosphere), it'll hover at that spot forever. This is Newton's first law of motion.
Inertia only comes into play here when the drone is accelerating to that velocity, as it determines how much force is required. This is Newton's second law. Inertia is the mass in F=ma.
So if what you need to hover w/r to the Sun at the equator is equal and opposite surface velocity, there's no point in ever going 2000mph. You just get to 1000mph and either cut the engines (if there's no drag) or keep firing them to maintain that velocity.
You'd only need more/less speed if you wanted to change where exactly you want to hover. Maybe you wanted the Sun to be directly overhead or something.
The case with an atmosphere is no different than swimming against the current in a river. You want to stay at rest w/r to the river banks, you swim as fast as the current does, only in the opposite direction. Any other speed will move you w/r to the banks. And if you stop swimming = applying force against drag of the medium you're in, the current will quickly carry you away.
