Counterintuitive Result Regarding COM Of A Hemispherical Shell
  • Thread starter Thread starter GPhab
    Shell
The discussion explores the center of mass (COM) of a hemispherical shell compared to a semicircular wire. While the COM of the semicircular wire is at (0, 2R/π), the COM of the hemispherical shell is found to be R/2 above the center. This discrepancy arises because the semicircular wire does not accumulate mass at the center like the hemispherical shell does, leading to a higher density at the top of the hemisphere. Participants express curiosity about calculating the COM of a hemisphere using integrals. The conversation highlights the intriguing differences in mass distribution between the two shapes.
GPhab
Follow the below four steps to amuse yourself
1) Take a semicircular wire. You know that its COM is at (0,2R/\pi). Now pass an axis through its COM and perpendicular to the line joining its ends.
2)Rotate this "half-lollipop" about the axis fixed till it comes to another position. The COM obviously didn't undergo any displacement.
3)Do this is an umpteen number of times and imagine as if a new wire is created for each position. The COMs of all of these wires coincide and should be at the coordinate mentioned in step 1 (Including a Z-co-ordinate, which can be taken as zero)
4)But the COM of a hemispherical shell is R/2 above the centre!
COM-centre of mass
because the wire isn't shaped like a wedge.
If the wires have finite thickness, then there's an accumulation of mass at the center of the hemisphere where multiple wires would cross. The density at the center (top) of the hemisphere would be higher than at the edges, which differs from a shell of finite thickness.
Jeff got it right. To what extent did it amuse you?
Speaking of which, can anyone show me how to calculate the COM of a hemisphere (integral way)?
We assume that the hemispherical shell is being built up from the sum of semicircular wire. Each element of the semicircular wire has COM at the point A. But the cummulative sum of the elements has COM at B. That puzzling :confused:
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
